The electric fan wasn't kicking on. I thought it was bad but it runs when I uplug the wire from the temp housing. I've switched relays for the a/c with ones that I know work. All fuses in the PDC are good. When I put a jumper from the battery to the a/c wice the clutch clicks like it works, have'nt done this when it's running though. Am I missing a relay under the dash inside. Is there a low 134a level switch somewhere keeping it from cycling on. The sight glass looks like it's full on the receiver-drier. As for the temp, the sender is new ,fuses under dash are all good. Would the gauge needle in the panel be shot? All on a 1996 XJ,4.0, 4x4,auto. Power windows and door locks only, not sure if it matters but what the :flame: thought I would let you know.
