Ha, I need some added flex to get the pass side mount on. The mount will not sit parallel to the bracket for the bushing to slide in. I tried moving the motor up and down but no luck yet.
After moving the engine around for a couple hours I finally got the mount on. Not excited about having to remove the oil filter and move the bracket to get the thru bolt off and on. Gonna soak in some suds to relieve pain now..
I couldn't keep a motor mount in my '68 Plymouth for the longest time. I'd replace it and inside of a week it'd pop again. Turned out I had a busted tranny mount, too, so the torque just overcame the one motor mount. However, point is, my answer was half-inch chain and a thru-bolt.
Worked like a charm. Was on there until the engine eventually breathed its last, near the 15/10 interchange.
