    More Information - Join/Renew
Rock n Roll in CA
Looks to me like the entire blurred out part of the image is all his body fluid, likely a head shot from the axle / hub.
The 4x4 is suspect, was take a jack-stand that spit out ? The hi-lift was probably used to get him out.
Bottom line ........ a REAL F'ed up way to go.
I recall an earthquake at the shop one time, I had three cars racked...nearly shit myself...but none fell.
A couple of years ago I bought some 12-ton jack stands from HF. The first time I used them they both collapsed as soon as I lowered the front axle of the Jeep onto them. I discovered that the pawls were cast steel, and VERY roughly cast. They just didn't have teeth to sufficiently engage the matching teeth on the riser. I took them back. About a year later I was hanging out at Avery's place when a HB 12-ton jack stand collapsed under Bricker's jeep, with Bricker sitting on the ground right next to it. Thankfully, no one was under it. BE WARNED -- I'VE PERSONALLY SEEN HARBOR FREIGHT 12-TON JACK STANDS FAIL TWICE. ITS A PIECE OF CRAP PRODUCT AND NOT WORTH THE RISK, in my opinion.
BTW, lest anyone think I just have some sort of axe to grind with HB, I have owed a set of their 6-ton stands for years and use them regularly.
Was at Dale Bros. Brewery seeing the Crown City Bombers play....almost didn't notice the quake until everything was swaying in unison.:gee:
I’m heading up to Santa Ynez for the weekend. Gonna catch the CCB at a bar up there on Saturday night.
Why did I think you meant Bay City Rollers?
:guitar:
:laugh2::roflmao::laugh2:
