View Single Post
  #12
Old August 15th, 2017, 07:08
N8N_99xj N8N_99xj is offline
Re: Stripped throttle position sensor hole, what to do?
If it is a blind hole you will need a "bottoming tap" for the Helicoil, the kits usually come with plug taps.
If this is a one off just buy the kit and cut the end off the tap with an abrasive wheel and dress it on a bench grinder.
