Huerito
- Long Beach
96 4.0 XJ 2WD OBDII
So I can't pass smog until I clear this code. I replaced the O2 sensor, it was old anyways.. and the CEL came back on. I have ran a search and it seems that other 96 XJ owners with the same code have also found out their O2 sensor is ok.
I don't have the 96 FSM and since this XJ is OBDII, I cannot rely on the key on-off trick to read codes. I just finished fixing a blinker problem on this car, (faulty relay), and I still have to fix the horn and cig lighter that don't work.
My question is, since the O2 sensor was not the culprit, and I have a high voltage code.. could the blinker, horn, cig lighter and O2 sensor problems be in some way related? I am wondering if the problem might be somewhere in the relay center under the dash. That is where the blinker issue was... and I think this is where the voltage regulator for the O2 is.. I don't know. Can anyone chime in? If you have a 96 FSM, could you PM me please? I wanna get this done during this holiday days off.
