View Single Post
  #3
Old January 8th, 2019, 10:19
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Re: rebuilding front DS slip joint
If worn excessively, the slip yoke would need to be replaced, and the drive shaft assembly rebalanced. Your local clutch and u-joint shop will be able to quote you for the job.
I'm starting to realize people on the Jeep forums are highly expert mechanics .....
