View Single Post
Old January 19th, 2008, 18:56
Frank Z Frank Z is offline
Re: Winter Project - 2008
Made a little progress today. Found out that the 98 transmission is set up a little bit different than my current 97 tranny. First up I had to remove the tailcone and swap the rear output speed sensor and rotor(changed from 1-pulse/rev to 4-pulse/rev.) You can see the 97 rotor on the bench beside the new tranny.
Seemed like a good time to replace the existing filter.
Yes I cleaned and reinstalled the magnets.
Daniel helped out today, couldn't have got the transmission in without his help (Thanks Son!!)
New transmission is now installed and the transfercase is back in palce as well. More work tomorrow as time allows.
Thanks for looking!
