traction bar, when is it worth adding?
4x4JeePmaNthINg
Colorado
is a traction bar worth adding or not worth adding for any particular tire sizes small or large.
im on 33's now and I am curious of this addition and if it is worth investing in for its traction improvement.
it would be added to a C8.25 29spl and i would need a new or additional modified cross member for mounting.
also are there any cons to this set up?
i appreciate any info
I've never seen the need on any of my XJ's. I have built a couple for other vehicles but it mostly depends on your spring pack. There are no downsides to a properly built one.
There are no cons to one. I built one because I broke a driveshaft trying to bump up and over an obstacle. Plus I have pretty worn out leafs and long shackles with relocation brackets
It's hard to tell, is that near the diff?
I don't know who the hell homeslice is, but thanks for the reply.
Homeslice went around in '05. The name burnkat conjures up sort of a beatnik/ hipster vibe which suggests you may be familiar with this nomenclature.. haha.. sorry..
Yeah, you couldn't be more wrong. If I had my way they'd all be euthanized in vitro.
So I changed up the design of mine. I have a flat belly and want to keep it that way. My old traction bar had a shackle but it went through the floor which I wasn’t too fond of. So I made a slip and twist design and the shorter bar is completely adjustable. It’s built like a radius arm. Much more compact without the shackle. Only possible downside would be a hard hit bending it and therefore not allowing it to slip and twist. We will see how it goes
Traction bar is the only answer. Especially with a manual. All of the torque transfer. Its super fun.
I have seen designs that use a sliding shackle on a cross member that work very well.
Would you mind posting up some pics of the new arrangement?
