Renix Ignition module
POSrenix
simi valley
Is there a way to do away with the ignition module i wired in a MSD blaster coil and in order to do this i jammed some bolts in the module where the oem coil attached to i would like to find a way to do this cleaner, I thought i read somewhere you can use an earlier chrysler module:confused1:
Interested in this as well. I think it would be the same as replacing the ignition on anything from the 50s or 60s or 70s like hot rods do on a small block with a distributor.
Photos, and period at the end of sentences, would help.
