Old June 22nd, 2009, 04:04
F1504x2 F1504x2 is offline
88 XJ Blowing Oil
We have a 88 Cherokee XJ with a 4.0L with 140k miles and the line coming off the top of the valve cover and going to the air box has oil in it and it's making a mess of the air box. How can i stop/fix this?
Thanks
Old June 22nd, 2009, 06:27
superdave superdave is offline
Re: 88 XJ Blowing Oil
http://jeep.off-road.com/jeep/articl....jsp?id=257985
Old June 22nd, 2009, 06:45
Thanks, Superdave
Old June 22nd, 2009, 07:38
winterbeater's Avatar
winterbeater winterbeater is offline
It also helps to just make sure that the other line going from the intake manifold to the valve cover is clear. If this blocks up, the blowby can only go down the other line to the air cleaner. The line from the air cleaner is supposed to supply fresh air to the valve cover as the intake manifold draws that air through.
Old June 22nd, 2009, 07:43
Good information, I'll start checking things tonight.
Thanks
A/C blowing hot only when it is hot and humid MattS OEM Tech Discussion 12 July 29th, 2008 12:52
CB blowing fuses ethernet NorthWest Chapter 13 July 2nd, 2008 23:27
A/C Fuse keeps Blowing Surffshman OEM Tech Discussion 2 June 12th, 2008 22:56
15A Fuse keeps blowing? Please help!! pancake OEM Tech Discussion 40 January 2nd, 2007 18:18
A/C blowing at 60F blackbat21 OEM Tech Discussion 13 December 3rd, 2006 15:19
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
