Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Chapters > North Atlantic Chapter > NAC Classifieds
NAC Classifieds ONLY Local Sale Items here.
Old June 1st, 2009, 10:14
MoparManiac's Avatar
MoparManiac MoparManiac is offline
WJ knuckle swap
Up for sale is everything you need minus a track bar and WJ lower ball joints to complete the WJ knuckle swap.
With this setup, I could lock up my 35x12.50 MTZs without a problem. Steering becomes crossover and was very responsive.
Here was the setup on my jeep...
Everything that was welded was done by a professional shop (www.baystateoffroad.com)
WJ knuckles and calipers off of a '99 WJ (Teeves style, 1 = JY 1 = ~8k miles on it)
Sport Trac Rotors and WJ brake pads (~10k miles, minimal wear)
JKS knuckle spacers
Go-Fer-It TRE flip inserts for OTK steering
JKS tierod and draglink (1.25" OD x .375" wall)
JKS OTA bracket
All 4 TREs (TRE at pitman arm is junk - have a new one. Draglink TRE at knuckle is junk - is a RHD TRE, can get for buyer for $30 new)
$450
Can throw in the correct hub bearings('00-'01 XJ), with ~10k miles on them, and a set of stock shafts ground for full circle snap rings (U-joints are stiff and could use replacing) for $550.
Old June 3rd, 2009, 06:28
Re: WJ knuckle swap
Bump...
Need this stuff gone, make me a reasonable offer.
Old June 3rd, 2009, 06:36
5spd_xj's Avatar
5spd_xj 5spd_xj is offline
<<the good ol days
Re: WJ knuckle swap
Is it posted on NEOW, Colin? Maybe even try Craigslist? I'd hate to see you lose so much on it if you haven't tried all the possible avenues of selling it...
Old June 3rd, 2009, 08:52
Re: WJ knuckle swap
On NEOW and my club's forum.
I'll put it up on craigslist.
Rate This Thread:
WJ knuckle swap? trail rate this Modified Tech Discussion 2 January 25th, 2009 16:41
WJ knuckle swap on a RHD gorman Modified Tech Discussion 15 January 6th, 2009 04:45
wj knuckle swap... recycledxj Modified Tech Discussion 6 June 30th, 2008 13:47
wj knuckle swap jdxj Modified Tech Discussion 6 October 31st, 2007 23:18
TJ to XJ knuckle swap wascobi Modified Tech Discussion 3 June 3rd, 2007 21:00
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
