Old May 15th, 2009, 16:38
Johnnie Walker's Avatar
Johnnie Walker Johnnie Walker is offline
Piece of Fish!
Cooling system flush now crank/no start -Renix
In the middle of cooling system flush/replace t-stat. Have it mostly buttoned up ready to go, was going to burp the system, but the XJ wont start now. It ran fun until I went to start it now. Please help.
Old May 15th, 2009, 16:50
joe_peters joe_peters is offline
Re: Cooling system flush now crank/no start -Renix
Fuel, spark, air, compression.
Check for fuel at the rail, use the Schrader valve.
Check for spark at the plugs.
Did you get things wet, like the distributor?
Old May 15th, 2009, 16:56
Piece of Fish!
Nothing is wet.
Old May 15th, 2009, 17:00
Originally Posted by Johnnie Walker View Post
Nothing is wet.
Do you have fuel and spark?
Old May 15th, 2009, 17:02
Piece of Fish!
yes
The only thing I could think of, which I doubt is.. where the drain on the rad is there was a single wire with a connector that was hanging, but from the looks of it its been there for a while. Unless this is the problem?
Old May 15th, 2009, 17:14
yes
I wouldn't think so.
Pull a couple plugs and see if they are wet.
Is your spark strong--blue, or weak--yellow?
Old May 15th, 2009, 17:35
Piece of Fish!
plugs are fine, spark is blue.
Old May 15th, 2009, 18:11
Piece of Fish!
Well, it decided to start.. damn Heeps (=
Old May 15th, 2009, 18:44
You just haven't been paying enough attention to your XJ lately and it decided to sulk!
Old May 15th, 2009, 22:25
JeepCherokeeGuy99 JeepCherokeeGuy99 is offline
its the connector at the t-stat. if it ever does it again just disconnect and reconnect it.
cooling system flush, with city water? traildmg99 OEM Tech Discussion 7 April 22nd, 2009 19:18
Radiator/Cooling System Flush sublime600 OEM Tech Discussion 1 October 19th, 2007 00:48
Cooling System Flush - Hardcore! GSequoia OEM Tech Discussion 11 October 30th, 2005 10:44
Cooling system flush machines RichP Non-Tech / Off Topic 2 June 25th, 2004 22:20
Bad Experience with Cooling System Flush? bleech1 OEM Tech Discussion 10 November 3rd, 2003 18:50
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
