Old May 15th, 2009, 13:21
jonnyz123's Avatar
jonnyz123 jonnyz123 is offline
question switching from 0331 xj head to 0630 tj head
I have a cracked 0331 on my 2000 xj and I found a head off a 98 TJ he does not have the exhaust manifold. I know the ports are different from the 98 to the 2000, can I get a manifold off any 98 4.0 or does it have to be xj? Any help would be appreciated. Also are there other years besides 98 that I could use? Thanks in advance!
Old May 15th, 2009, 14:21
Erik Litchy's Avatar
Erik Litchy Erik Litchy is offline
Re: question switching from 0331 xj head to 0630 tj head
last i saw the ebay manifolds were dirt cheap.
http://shop.ebay.com/?_from=R40&_trk...All-Categories
Old May 15th, 2009, 20:11
winterbeater's Avatar
winterbeater winterbeater is offline
'99 and earlier should work. Whatever was on the 0630 and 0771 heads. Don't know if it has to be XJ. Don't see why, as your going to fab up a new connection to the cat anyway.
0331 to 0630 head conversion question MNJeeper OEM Tech Discussion 1 November 11th, 2008 16:52
0331 head swap question GrimmJeeper Modified Tech Discussion 27 September 8th, 2008 21:56
valve carbon or 0331 head issue? 0630 swap? wilsmick OEM Tech Discussion 12 May 22nd, 2007 21:13
Need a 0630 head- jfs3674 Wanted: Private Party Only 0 November 3rd, 2006 14:24
