Old March 18th, 2009, 10:10
Windowsrookie Windowsrookie is offline
Mopar door hinge repair kit.
Has anybody installed the door hinge repair kit on a model older than 1993? The TSB says it's only for 1993-1997 Cherokees. I have a 1989 Comanche and the top hinge on the driver's side is pulling away from the body. I'm wondering if the dealer won't install it because it's not in the listed years on the TSB.
Old March 18th, 2009, 10:18
IslanderOffRoad's Avatar
IslanderOffRoad IslanderOffRoad is offline
NAXJA Forum Addict
Re: Mopar door hinge repair kit.
Any more details on this?
John V.
01 XJ Sport 2 door 5spd/4WD- 4" lift, 35" BFG ATs, JCR bumpers, Rubi 44, Ford 8.8, 4.56's, ARBs
Old March 18th, 2009, 10:21
RichP's Avatar
RichP RichP is offline
I remember they did a cherokee on trucks or whatever that show is on spike tv during the powerblock when they pulled the frame back out, it was just on a couple of weeks ago, not with Stacy either. They had the fender off and welded in some kind of plate or something that was supposed to be the best fix.
Old March 18th, 2009, 10:35
ChiXJeff's Avatar
ChiXJeff ChiXJeff is offline
Curmudgeon
I'd bought the kits for a 92, but never got around to bolting them in. The 92 hinges looked identical to my 94's.
ChiXJeff
Lifetime member
"Jeeps are Cherokees. All other models are wannabes." Deb. K.
Old March 18th, 2009, 13:21
Pelican Pelican is offline
NAXJA Member #1191
I don't know if this is of any interest to you, but there was a really neat fix for this problem posted in Mod Tech a couple of weeks ago:
http://www.naxja.org/forum/showthrea...ighlight=hinge
Old March 18th, 2009, 20:12
That looks like the best option for fully separated hinges, but mine is still mostly attached with no rust. I'm just wondering if the Mopar kit will work with 92 and older models.
2 door hinge repair ColoradoJeepXJ OEM Tech Discussion 6 February 26th, 2008 19:02
Door hinge repair write up Gojeep OEM Tech Discussion 9 June 6th, 2005 21:27
Door Hinge repair kit inststuction link Dave in ABQ OEM Tech Discussion 4 May 10th, 2004 19:37
chrysler door hinge repair kit mikeyl OEM Tech Discussion 9 April 15th, 2004 19:25
Door hinge help... 5-90 OEM Tech Discussion 4 May 3rd, 2003 20:46
