Old January 12th, 2009, 17:14
xSUx SGT BAKER's Avatar
xSUx SGT BAKER xSUx SGT BAKER is offline
aw4 shift cable adjustment
Does anybody know how to adjust the cable that shifts the aw4? I'm finally getting my jeep together and i can't get it to go into park because the cable is not adjusted properly. in the FSM it says to "release the U-shaped cable adjuster clamp" (i hope i didn't break the rules with that one, if i did can someone please remove it) but i cant figure out what they are talking about. I took the little clip off that holds the spring on the cable but i don't think that is the one they are talking about.
Old January 28th, 2009, 17:54
randyf's Avatar
randyf randyf is offline
Re: aw4 shift cable adjustment
From another post I just checked out from 2006...
The throttle body cable connects the throttle to the tranny via cable. This controls how your tranny shifts. When you push the gas to the floor it causes the tranny to shift harder at higher rpm's, and just the opposite when you are light on the gas.
To adjust find the end that hooks to the throttle body. You'll notice that where the cable clips into the metal mounting bracket, there is a plastic housing that has a button that is in the shape of a half circle. Press it and push the cable into the plastic section, it should move in about 1/4" to 1/2". Now you have reset the cable and are ready to adjust it. To set the cable simply get in the drivers seat and press the gas pedal all the way to the floor (with the engine off). While you do this you should hear a series of clicks from the throttle body area, that is the cable setting itself. Thats it, give it a try. Hope this makes sense to you, it is very easy to do.
Old January 28th, 2009, 19:50
well, maybe i didn't explain the cable good enough , but we are talking about different cables. The cable that i'm having trouble adjusting is the cable that goes from the shifting lever in the cab, to the transmission to shift from Park to Reverse(etc..). I really do appreciate that you tried to help though
Old January 28th, 2009, 20:58
8Mud's Avatar
8Mud 8Mud is offline
The only way I've adjusted one is to hammer on the bracket, but I'm sure there is an approved method I know nothing about.
http://www.lunghd.com/Tech_Articles/...djustments.htm
Old January 29th, 2009, 22:18
i was going to make a spacer to make it in the right position but the hammer sounds easier lol thanks
Old February 1st, 2009, 19:09
Stefan Spencer Stefan Spencer is offline
Anybody know which is the return line for the tranny cooler in the radiator?
AW4 Shift cable adjustment gcurtis OEM Tech Discussion 2 January 6th, 2009 12:33
throttle cable adjustment? rufus_1111 OEM Tech Discussion 1 July 22nd, 2008 21:47
AW4 TV Cable Adjustment Q CantonXJ OEM Tech Discussion 1 May 23rd, 2006 19:03
Shift Linkage Adjustment greenday9d1 OEM Tech Discussion 1 August 23rd, 2004 18:21
Shifter Cable Adjustment???? eric91xj OEM Tech Discussion 2 May 5th, 2003 18:01
