Old January 4th, 2009, 07:48
mbogosia's Avatar
mbogosia mbogosia is offline
Vibration/Noise issue solved!
I have to post this because there has to be someone else out there as dumb as me that would do this. I installed a new TC with a SYE. After that I still had a weird noise/vibration issue. 4-LO also would not stay in. Been like this for months. I discovered that I put the transmission mount with the 4 bolts coming out on backwards. See in the following picture how the bolts are closer to one side. So when I stuck the cross member back on and bolted it up everything was pulled to the side by about 1.25". This moved my shift linkage up against the wall and made it crooked. It also caused my drive shafts to be shifted to the side and not lined up with the diffs. I never noticed this. Although I do remember fighting the crossmember to line up.
overheating at freeway speeds issue still not solved!!! AZRockRunner Arizona Chapter 41 June 17th, 2007 01:18
Vibration noise (not much actual vibration) with bigger tires dfrissell Modified Tech Discussion 12 May 21st, 2007 19:45
interesting AX-15 issue, semi-solved gmars OEM Tech Discussion 4 December 6th, 2006 15:00
Vibration at 1000 rpm solved!! Fish'nCarz OEM Tech Discussion 7 September 20th, 2006 05:40
I think I solved my overheating issue! GottaBeJeep Modified Tech Discussion 7 June 14th, 2005 19:33
