Old September 1st, 2003, 17:40
vintagespeed vintagespeed is offline
York belt path, pic
I finally re-routed my belt path & picked up a new shorter belt at Pep Boys today. They stock serp. belts in all different sizes in 1/2 inch increments, which made it super easy to find the right size. The part number is the size in circumference.
Anyway, I re-routed my belt off of the mechanical fan because of clearance issues with the belt at the idler & mech fan pulley. This setup looks fine to me and doesn't cause intereference problems anywhere, I just wonder if the alternator pulley has enough tension. I may have to add an idler later on.
On a side note, how is the mech. fan shaft removed from the bracket? Can I pull it out without having to remove all the brackets?
I'll be running the dual Nissan fan setup that another poster put up last week, that looks like the hot ticket for my setup.
Old September 1st, 2003, 19:09
Bender Bender is offline
That mech fan pulley is held in by a press fit bearing. It's some unusual bearing that is very long compared to it's diameter. You can remove it but it takes a lot of beating with a hammer or a good press. Either way you'll have to unbolt the aluminum bracket it is pressed into to get it out.
Also, I was the one who posted the fan upgrade. Since the installation I've had several days with temps around 90 F without taking into consideration humidity and even in heavy traffic the dual fans on their "low" setting is enough to keep the 4.0L cool. I'm yet to require their "high" setting or the pusher fan on the front of the rad.
By the way, that's an interesting ignition coil mounting location. Did you free up the space on the pass side wheel well for your shocks?
Old September 1st, 2003, 19:14
useless useless is offline
NAXJA Member # 525
That's awesome, good work.
Old September 1st, 2003, 20:17
xjjunkie xjjunkie is offline
might think about belt wrap on the alt. pulley, not very much contact area, might slip when under a heavy charging load.
scot
Old September 1st, 2003, 23:21
Yeah, that's what I was worried about. It's good now but under load I wonder how it'll work. I figured I might add an idler between the pump & alternator?
Belt tension on Serpentine belt? Planetcat OEM Tech Discussion 36 July 10th, 2009 00:58
pic test Lee 94XJ TEST Forum 1 December 7th, 2003 08:09
pic test Lee 94XJ TEST Forum 0 December 6th, 2003 20:44
Serpentine belt on a 97+ RichP OEM Tech Discussion 2 August 31st, 2003 14:33
PIC Test KINGSIZE TEST Forum 2 April 7th, 2003 02:48
