Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Other Technical Forums > Advanced Fabrication and Engineering
Advanced Fabrication and Engineering For when your build is going off the charts. Wildly modified vehicles and straight up buggies welcome.
Old September 19th, 2006, 12:29
ashmanjeepxj's Avatar
ashmanjeepxj ashmanjeepxj is offline
Front Coilover mounting Hoop, Pics..wanted.
Im looking at ideas for front coilover hoops. I have 16in 2.5in coilovers, with 6in of up travel mounted on top of the dana 60 inner C so it will come through the hood. Id like to not need to move the brake MC.
I found these pictures on XJ db one with the brake MC and one with it removed. Id like to not move the mc.
This is what I have to work with, no 4.0 so I have more room then most. This red lines show about where the coilover mount would be with weight compressign the springs...
I could run tube from the a-pillar spreader to the radiator hoop similar to the second picture. that would be alot of work...
Old September 19th, 2006, 17:19
hadfield4wd hadfield4wd is offline
Re: Front Coilover mounting Hoop, Pics..wanted.
These are Arcticxj's. If I remember correctly the cut the cross brace and put flanges in so he coud get to the engine.
Old September 19th, 2006, 17:27
That is more like I was thinking.
Mine will need to be higher and the cross tube would need to be further forward.
I like that setup, any other versions?
Thanks
Old September 20th, 2006, 20:06
Jeff 98XJ WI Jeff 98XJ WI is offline
So Ashman, where have you been? I haven't seen any posts from you in quite awhile. Did you get that engine/drivetrain swap finished? Is there a thread showing the finished product somewhere? How's it working? Jeff
Old September 20th, 2006, 20:45
tealcherokee's Avatar
tealcherokee tealcherokee is offline
its up a PBB..... def my favorite thread
Old September 20th, 2006, 23:53
Goatman's Avatar
Goatman Goatman is offline
I think you'd want a hoop that runs lengthwise of the Jeep to minimize the hole in the hood. I'd make a hoop to come off the side of the frame rails pretty much straight up through the hood with the shock mounts attached to the bottom of the hoop. Weld two short pieces of tube straight out from the frame, then weld the bottom of the hoop to the top of those short pieces. You can then tie the hoop into other tubing to the side underneath the hood.
One idea......
TEAM/PETTY CASHRacing........2013 Ultra4 Stock Class National Champions
Check out the TEAM Facebook page for the full story of our 2013 winning season: https://www.facebook.com/Team
Thanks to , Falken Tires, Bishop-Buehl Racing Engines, Ten Factory Axles, Brown Dog, Hooker Harness, BILSTEIN, Raceline Wheels, WARN, G&G Auto Repair/Off Road, Yukon Gear and Axle, Full Traction, Cal, Russ, James, and many, many others.
Old September 21st, 2006, 08:29
The brake MC is in the way, The hoop would have to go almost out to the fender not straight up, The tire would hit the hoop on up travel, and the tire would hit the coil over. It could be an option like shown on the red cherokee to do that hoop then run a second hoop form the top of the frame rail to the top of the hoop near the fender. still the tire coudl hit the hoop but not the coilover.
I agree If there were no clearance issues Thats the simplist solution. Ill have to realy consider moving the Brake booster and MC. If its not to difficult that would make more sence to move then build a jungle gym around it.
I do plan to cut into the fenders as needed to get uptravel. The wheel well dosent fit 42s very well. on my past leaf spring setups Ive only had about 3-4in of vertical up travel
Old September 21st, 2006, 12:50
Goatman's Avatar
Yeah, I saw that when I was working on mine this morning. But, it looks like you could run the hoop just to the outside of the M/C and have the shock mount tabs to the inside of the hoop. You might not be able to lean the shock back as far as you want, if you want to lean it back that far, but there's room in front of the M/C for the shock to go, especially since the lower mount is further forward on the inner C.
Old September 21st, 2006, 14:18
FernXJ FernXJ is offline
What if you fit a tight hoop in front of the MC, then tie it into your tubes outside the fenders. Would keep your supports out of the tires way. Then you could weasel in linking supports across the engine. Doesn't sound or look like you'll fit anything simple and easy.
Rensing
Old September 22nd, 2006, 11:36
ArcticXJ's Avatar
ArcticXJ ArcticXJ is offline
You are correct, Hadfield. I havent looked at those pics in awhile.... here are a couple others. Feel free to question any of the mounting. I get a lot of inquiry as to why it was built as it was.
... Ashman, I've admired that XJ (xj... right) of yours for a long time, and have been following the build for some time. Actually, you were just rolling that thing out into your driveway with an air hose chucked up to it to test the airshocks back when I was putting 2" poly spacers on top of my coils to fit my 33's.
Old September 23rd, 2006, 11:59
Any thing you would do different?
I just got my wireless at home installed. Its haulin ASS. Its feals faster then my 100MB connecton at work, just less traffic... Im stoked. more web wheelin
Old September 25th, 2006, 15:26
ArcticXJ's Avatar
Suspension wise, I wouldnt do anything different, except locate the axle a bit further forward. I'm happy with the way its setup, outside of that.
If I could do it ALL OVER again, I never would have had to use the coilovers because I would have built a housing from the aftermarket using correct length tubes to allow my coils to sit where they sat on the d30. Even with the '78-'79 hp60, I wouldve spent a grand or more, and ended up keeping only the hubs, knuckles, and spindles. I'd be better off just spending the money for a Pro Rock housing or one from RockCrusher, Crane, etc.
Oh, and as far as the rates on your rig, they'll need to be fairly stiff. I run a 250 tender over 300 main spring, and its just right. I started off with a 250/400 combo and it was plenty stiff. Too much so. I'd assume your front end with all the tubing and that SBC would benefit from at least 250/400. I still have the 400lb coils sitting in a box in the Jeep by the way, if you'd like to give them a try. Might save you a couple bucks in the long run.
Old September 25th, 2006, 17:55
What length coil overs, what length coils?
Im runnign 16s, I want a 16in over 16in coils.
Today I tack welded all my links in place, no binding on up or down travel. I set my bumpstops but when I articulated it I only get 10in of down travel til my drivers side upper link hits the pinnion, housing, and lower link all at the same time. The passenger side also hits the lower link at about 10in of down travel.
Ill have to shorten the upper links get them alittle wider out, and move the axle ends up about 3/4in and it will be better. I hope that will get me the full 16in of articulation. I might loose my pinnion angle control with the shorter uppers from 36in now to probably 30in. If I have drive shaft bind Ill just center limit strap it. Frustrating to build and re build.
Old September 25th, 2006, 21:12
ArcticXJ's Avatar
Ahhh, sorry. My Fox's are 14's. The reasons you are stating for frustrations in trying to accomodate all 16 inches of those shocks' available travel are exactly why I have the 14 inch models. I knew that my mechanical steering would be maxxed at with 14" shocks, and I'd be running into pinion angle, driveshaft, and other problems.
Just because you *can* get 16" of travel out of them doesnt mean you necessarily need to. Limiting straps are your friend.
Old September 26th, 2006, 11:57
42s and the 350-th400-203-205 didnt fit in the cherokee easily.
Rate This Thread:
Wanted: Cross Enterprises rear shock hoop Incredible Hulk Wanted: Private Party Only 2 February 1st, 2005 18:34
Need pics of Ford axle track bar mounting 79yj Modified Tech Discussion 4 September 1st, 2004 21:05
progress pics of front coilover hoops Fullsizexj Modified Tech Discussion 47 December 11th, 2003 08:48
Anyone w/pics of rear shock hoop on their XJ? giranger Modified Tech Discussion 7 October 28th, 2003 21:50
Need pics, dimensions, etc. of skid plate mounting hardware btl_fed_xj Modified Tech Discussion 7 August 1st, 2003 18:47
