Old August 31st, 2003, 12:52
RichP's Avatar
RichP RichP is offline
Serpentine belt on a 97+
Just did my serp belt on the 98 for the first time, 180,000+ miles so I figure it's time. Pretty simple really cept for the alternator, $#(*$*%+#, my arms look like I was in a cat fight getting that loop around .
I removed the aux fan, connector is a PIA, has TWO releases, little red one and a tab, two screws, loosened the idler bolt and then backed off the adjustment screw, removed the belt, installed the new one and tightened if back up to snug, double and triple checked the routing They tell you to ignore the routing in the FSM if it differs from the one on on the shroud.
Used my krikit tension gauge to adjust to the FSM recommended tension of 180-200lbs, set it for 200. Fired it up and checked it again allowing it to run for a while, 2min, before I put the aux fan back in. checked the tension at two points, the run between the AC and wp/mech fan and the PS and wp/mech fan. Two different readings, 200 on the first and 180 on the second for ~190. We'll see. According to the FSM a used belt is supposed to be 140-160 lbs so I guess they relax some. A new belt is considered one that has been run for 15 min or less, so they must relax pretty quick
All in all I rate it a 2 or 3 only because of the fight with getting the aux fan out and looping the alternator and holding it all in place as you route the other pulleys, easier with an extra hand or two.
I'm glad I took the time to read the FSM as I was ready to pull the airbox and start looking for bolts under the PS pump.
Time for the transfer case....
Old August 31st, 2003, 14:13
Kejtar's Avatar
Kejtar Kejtar is offline
PostMaster General
Hmmm I don't recall mine being that bad and I got a 98 as well (with all the goodies: AC and so on...).... In any case, check tension on it once more after driving it for a day as it will stretch even more...
So what are you gonna do to you tcase?
Kejtar
Old August 31st, 2003, 14:33
RichP's Avatar
I have big hands and could not get a good bite on the adjustment pulley to loosen it without removing the electric fan, socket and ratchet were too long, I also did not intend on leaving any extra skin on that electric fan trying to loosen that bolt. Taking the fan out makes it easy and adds about 5 minutes once you figure out the connector...
Drain and refill with mobil-1 ATF. Also stopping at the dealer this week and picking up two more gallons of Mopar coolant and 4 or 5 quarts of AX-15 GL-3 stuff, also the Mopar HP plug wires should be in by tues. Next weekend is the annual flush.backflush, tstat and pressure cap weekend, got the Prestone Super flush 7 hour stuff so I'm taking my daughter who has her permit for a L-O-N-G drive on RT 80. I figure on tues or wed I'll be putting the weber on the YJ if it comes in.
Belt tension on Serpentine belt? Planetcat OEM Tech Discussion 36 July 10th, 2009 00:58
serpentine belt jaros44 OEM Tech Discussion 5 November 6th, 2003 12:15
98 XJ serpentine belt replacement billfires OEM Tech Discussion 6 September 25th, 2003 18:26
serpentine belt problems NitroDuck OEM Tech Discussion 11 June 16th, 2003 22:07
Serpentine Issues 4onDFloor OEM Tech Discussion 3 May 15th, 2003 20:40
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
