Old October 6th, 2008, 21:53
pimpgixxer04's Avatar
pimpgixxer04 pimpgixxer04 is offline
starter bad?
ok guys well i went to the store tonight to get some cookies for me and the wife and when i come out i get in and the rig wont start but all the lights are on and the windshield wipers are still working fine. It doesnt even click...i noticed it's been starting somewhat sluggish lately do you think the starter is the culprit.. i hope so cause i deploy friday and my wife needs this beast running for the winter... any help would be greatly appriciated...Oh and where can i get a starter pretty cheap...
Old October 7th, 2008, 05:37
Re: starter bad?
anyone?
Old October 7th, 2008, 07:06
Yucca-Man's Avatar
Yucca-Man Yucca-Man is offline
NAXJA Member # 683
Re: starter bad?
Get underneath and give the starter a whack - not hard enough to rock everything, but enough to remind it you're in charge. If it starts after that, get a replacement so your wife won't have to do that again while you're gone.
Jim www.yuccaman.com
Old October 7th, 2008, 08:29
Ivan's Avatar
Ivan Ivan is offline
I Jeep, therefore, I am..
Re: starter bad?
Put a VOM at the starter hook up terminals, and have someone try to start it to get a voltage reading . If all is good there, it's only 3 bolts and about 5 minutes worth your time to drop the starter, and have it tested an most autopart stores for free. If bad, then you are already there to buy a new one....
BTW...The symptoms you described were the same for my starter, which in the long run turned out to be bad.
Member #133
Kleptomaniacs help themselves, because they can't help themselves......
Old October 7th, 2008, 09:11
mjma's Avatar
mjma mjma is offline
Re: starter bad?
Yeah...it will do that sporadically until you're on a really tough trail where there is no way anyone could pull you out, either forward or backwards, and you shut your motor off and then go to start it and it finally decided that it was totally done with life.
Change it now...it's easy.
Old October 7th, 2008, 14:37
Re: starter bad?
k so i changed it out and turns out it was the starter.. thanks for all the info.
Starter gilby7887 OEM Tech Discussion 7 April 26th, 2007 17:40
starter went out, fixed it, now starter doesnt get a signal?? HELP!! DangerousJordan OEM Tech Discussion 4 February 19th, 2007 18:43
starter... jeepinxj05 OEM Tech Discussion 1 March 29th, 2006 16:21
Starter or NSS? Hickey OEM Tech Discussion 18 July 7th, 2005 21:57
I Need a Starter... Rock.Wgn OEM Tech Discussion 7 June 14th, 2005 14:29
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
