Old October 1st, 2008, 19:51
imajeep2 imajeep2 is offline
99 xj heat issue.... hot/cold doesnt work
the heat/cold dial stopped working,,,,,
only blows cold....
i dont mind it being stuck... just need it to blow hot when on.
Old October 5th, 2008, 14:44
XjRomper's Avatar
XjRomper XjRomper is offline
Re: 99 xj heat issue.... hot/cold doesnt work
hey buddy. im kind of going through a similar situation and just ripped apart my dash. did not help me one bit but i might have some good info for you! if you look under the dash on the passenger side you will see this little motor housing with some wires coming out of it(close to the center console). this thing should move when you turn the temp dial. that part of the HVAC system is controlled electronically. if your vents arent changing from defrost to floor or dash then you have a vacumm leak. this part of the HVAC system is powered by intake vacumm. I hope for your sake that your not in my situation and have to take everything out to replace the heeater core. hope this info was useful.
took to shop now 4x4 doesnt work Kiefer316 OEM Tech Discussion 7 April 26th, 2008 04:16
Jeep doesnt start, its cold. need to get to class HeavyMetal OEM Tech Discussion 11 February 6th, 2007 20:04
why doesnt my heater work? streetpirate OEM Tech Discussion 11 January 25th, 2006 06:51
Dimmer doesnt work . why ??? generalleexj Modified Tech Discussion 0 May 6th, 2005 06:45
Aux Fan doesnt work redyouch OEM Tech Discussion 11 February 16th, 2005 15:10
