Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Other Technical Forums > Jeep Street and Performance
Jeep Street and Performance Do you like to go fast in your Jeep?
Old September 27th, 2008, 11:28
Boostwerks.com's Avatar
Boostwerks.com Boostwerks.com is offline
NAXJA Supporting Vendor
Cool Boostwerks.com turbo XJ build...
It's taken over two years to begin the final fabrication project to be able to start selling the turbo kits, but I can assure you I'm getting a hell of a lot closer.
Some info on the final design of the kit:
- Based around a readily available 57 trim Borg Warner T3/T4 with a 3" Vband turbine outlet (Retails for $650 new).
- Redesigned log manifold (using solidworks) to better position the turbo, and WG. (should be priced around $700, and warrantied for life).
- I will be selling just the Manifold, along with a seperate 3" DP, external WG option, 1.5" dump tube, and 2" SS charge piping kit. This will allow the end user to "peice" together a kit of their own, OR utilizing the same turbo I'm using get the major fabricated parts covered. This will allow those with no welding capability/fab knowledge to build a quality turbo system for their jeep, as well as those looking to use parts other than what I've developed the manifold for.
Here's the pics to prove it:
Borg turbo:
Tial 38mm external wastegate:
My custom 1/2" CNC'd head flange (only 1/2 pictured) along with the quality SCH40 304ss elbows used in making of the manifold (fully tig welded/backpurged):
I will have updated pics of the kit coming soon.
Any questions, comments or concerns are welcome!
Thanks!
Bryson at Boostwerks.com
Old September 27th, 2008, 13:17
besthaticouldo's Avatar
besthaticouldo besthaticouldo is offline
Re: Boostwerks.com turbo XJ build...
sweeeeeeeeeeeeeet
this is gonna be badass. bookmarked.
Old September 27th, 2008, 13:49
ECKSJAY's Avatar
ECKSJAY ECKSJAY is offline
Water is dirty
That's just damned sexy...
Old September 27th, 2008, 13:53
yossarian19's Avatar
yossarian19 yossarian19 is offline
I crave passing speed.
Looking forward to the kit.
Any ballpark on price?
Old September 27th, 2008, 16:47
CSaddict's Avatar
CSaddict CSaddict is offline
Hmm thats interesting you are still going back to the log idea. You gonna bag it or the heat soaking of the intake not an issue due to the fact it will sit low?
Im starting my turbo next week oddly enough. It will be a low budget build based on an up pipe.
Good luck and update a lot.
Old September 27th, 2008, 17:26
Thanks guys.
I won't have a complete kit, but will sell the main parts to get proper turbo placement and eliminate most of the hard fabrication. All the end customer has to do is collect some small parts to complete the kit. I'll obviously provide a complete list down to the PN's, along where you can source the rest of the parts. With that being said, I don't have any set pricing at this point but if your looking for ball park figures this is the best I can do:
Manifold - $600-$700
3" SS down pipe - $200
external WG option - $75
1.5" WG dump tube - $75
Intercooler kit - $400-500
No one said turbo charging was cheap, but the benefits are priceless. Selling the kits in this way also allow you to choose used parts if your main goal is to keep it cheap as possible. It's entirely possible to build a mild budget turbo setup for under $1500.
I gotta say man, that was not the reply I was expecting from you. Thanks a lot for the kind words.
The log design is simply the best option for what I'm looking for. Most jeep owners are looking for torque, and quick spool along with an inexpensive solution. I truely beleive that the log design is the only solution to both quick spool, and low cost. Sure I could build a tubular design, but I don't think most Jeep owners looking to go turbo are trying to find the small topend advantages they bring.
Also, the design of the log manifold has completely changed from that first manifold (It honestly flat out sucked). The new design is much more compact, mounts the turbo closer to the block, and a full 6"s higher than the previous design. I also had a new 1 peice head flange CNC'd which will make fabrication MUCH easier.
I will definetly be getting the manifold ceramic coated, and fabbing up a heat sheild between the manifolds. I don't think heat soak will be any worse than the factory manifold.
Keep me updated on your setup man! I'd love to see the progress. We definetly need to get more turbo jeeps out there. I'll also be keeping this thread as a "build thread" and updating it often.
Old September 27th, 2008, 18:26
CSaddict's Avatar
We always tend to see things a bit differently but we want the same end result. Im looking forward to the build.
Old September 27th, 2008, 20:21
alex22's Avatar
alex22 alex22 is offline
Very interesting. This just might go onto the stroker I have in the works. What piggyback engine management system do you recommend?
~Alex
urban yan urban yan is offline
lol. I hope this kit's going to happen... this time.
Old September 27th, 2008, 20:55
GrimmJeeper's Avatar
GrimmJeeper GrimmJeeper is offline
Dead man walking
dude.... that blanket is trippy as hell! im freakin out!
Old September 28th, 2008, 00:29
gradon's Avatar
gradon gradon is offline
bout time. Anyhow my bro Nick is in town and will be back from the M.E. for good in Nov. His T3/4 is still collecting dust in the shed(while his XJ is collecting sand) and I just got done telling him a day or two ago that I know someone who's working on a manifold. He finally got to drive the stroker he helped build and for some odd reason, I don't think he'll be satisfied with his.
Old September 28th, 2008, 00:31
gradon's Avatar
bout time. Anyhow my bro Nick is in town and will be back from the M.E. for good in Nov. His T3/4(turbonetics .63, iirc--I'm too lazy to search a prev post with the exact #) is still collecting dust in the shed(while his XJ is collecting sand--he took it with him) and I just got done telling him a day or two ago that I know someone who's working on a manifold. He finally got to drive the stroker he helped build and for some odd reason, I don't think he'll be satisfied with his.
Old September 28th, 2008, 13:22
JWFokker JWFokker is offline
The cost really isn't that bad, depending upon how much HP it generates.
Old September 28th, 2008, 14:08
~Alex
I'll be using the AEM F/I controller. It's really designed for OBDII vehicles, but should work just fine for OBD1s as well. It should be the next thing that I purchase.
You could probubly say that it's already begun. No worries this time man.
Some might find it expensive, but compared to ALL of the SC kits on the market it's a steal. Some reasons why:
- air/air intercooled
- MUCH more useable power
- MUCH greater power capability
- will maintain a better low load gas mileage
Old September 28th, 2008, 14:30
rav's Avatar
rav rav is offline
Glad to see some pics, those of us who would just like to buy a complete kit would you be able to help us out? what is the time line that we might expect for this?
Thanks,
Ravi
Rate This Thread:
turbo kit junkjeep Jeep Street and Performance 25 February 27th, 2007 01:10
AWD TURBO STROKER BUILD UP tealcherokee Jeep Street and Performance 43 January 2nd, 2007 20:33
turbo dss Modified Tech Discussion 5 November 16th, 2006 09:50
turbo? graVes14 Modified Tech Discussion 6 March 8th, 2005 11:58
STS Turbo Fred Jeep Street and Performance 2 January 4th, 2005 04:12
