Old September 11th, 2008, 12:51
squirrel80 squirrel80 is offline
A quick link for a -6AN fitting to the AW4 cooler line.
I was asked to post info on this fitting and hopefully it will be helpful for anyone else that is looking for a way to connect braided line to their tranny.
Here is the fitting and you will still need an o-ring with this.
http://www.jegs.com/i/Russell/799/670520/10002/-1
The tranny side is the 14mm x 1.5
you can just see the blue fitting in this picture
Old September 11th, 2008, 13:00
Skullver's Avatar
Skullver Skullver is offline
Still Flailing
Re: A quick link for a -6AN fitting to the AW4 cooler line.
edit: erased bad info
Old September 11th, 2008, 13:07
I'm being told by a Jeepspeed friend that the front line is the supply(hot side). An easy way to find out is to start your jeep cold and power brake it for about 10 seconds, shut off and feel the lines. The hot side will be revealed. I did not have this ability on the jack stands so I am taking his word for it.
Old September 11th, 2008, 13:11
Stallacrew's Avatar
Stallacrew Stallacrew is offline
The front line is the hot line.
Originally Posted by Skullvarian
cool deal. I used these fittings from ATI for -8 AN(http://store.summitracing.com/partde...rt=ATI-925138), they come in pairs and have the teflon sealing washer also(but were quite a bit more expensive). Looking really good there! Quick question but which of those lines is the supply to cooler(hot side?), I can't find the schematic I had and can't quite remember from when I took it apart.
Thanks
The fiiting that you show is 1/4" pipe thread and is not what the AW4 is. The threads are very close but I had the tranny out when we tried out all the fitting and the metric fitting is the correct one. I did notice that the 1/4" fitting will thread in all the way but it fits loosely and I would be afraid to torque down on it. Be careful using that style I would hate to strip out the tranny.
Old September 11th, 2008, 13:13
Skullver's Avatar
Still Flailing
thanks, jeep is not quite there yet either so.....looks like I'll be trying harder to find that schematic. I am trying to plumb the trans temp gauge right off of the hot side inline as opposed to trying to get a bung welded into the pan for it.
Thanks for the info, I'll update you when/if I can find that schematic.
Old September 11th, 2008, 13:14
Skullver's Avatar
Still Flailing
I did notice it was a bit loose, hmmm. I'll have to look into this further, thanks much
edit: damn, took somebody elses word for it and ordered them and after a quick comparison, you are right, they are slightly different At least I find out now.
Thanks!
Old September 11th, 2008, 13:32
53guy's Avatar
53guy 53guy is offline
That's awesome! Thanks a ton! My plastic attachments are leaking and need replacing. Got a quick question, do the plastic connections just unscrew to reveal the threads or is there something else in the way? Also, what Oring did you use?
Old September 11th, 2008, 13:43
Stallacrew's Avatar
You have to remove the plastic quick-disconnect (push inward and then pull out). then you unscrew the large steel hex shanked QD fitting. Then you replace the steel hex with the blue one and an o-ring. That way you can screw your hose on with a fitting rather than have a QD that will leak or hose clamped hose (like mine).
Easy peasy.
--Alex
Old September 11th, 2008, 14:07
Remember there are still the tranny cooler fittings and the radiator fittings to deal with. I have a Aluminum Raditor from Oscar's Radiator and an aftermarket cooler so these fittings are going to differ from jeep to jeep. This will not work with all the other fatory lines. I threw those away and built all my own. Also -6 seams to work best on tranny line I tried -8 on my old suburban with a Turbo 400 and I could not get the adapter to the radiator in -8 only -6. There is alot more variety of aftermarket specialty fittings for -6. I got the o-ring from an assortment kit I have, but any good parts store should be able to get something for you. Or use the factory o-ring that comes off the factory fitting.
Old September 11th, 2008, 14:31
53guy's Avatar
Edit, already answered my question.
Old September 11th, 2008, 14:34
I found a better pic of the tranny fittings.
Old September 12th, 2008, 12:42
One more bump before this thread gets buried in Modified tech.
Old September 12th, 2008, 13:32
silverslk's Avatar
silverslk silverslk is offline
So, are you running the trans to the stand alone cooler and not through the radiator portion at all or running through both? The reason I am asking is I was thinking about not running the radiator side and only using a stand alone trans cooler, thinking that off road the torque converter spinning might be some of my cause for running hot due to extra heat being introduced into the system.
Old September 12th, 2008, 14:10
Nope I will be running both coolers. I am hoping to keep everything below 200 degress all the time. I had a hard time keeping my tranny cool in a previous vehicle with just a stand alone cooler. That was a 600 horse big block with a high stall though.
Transmission Cooler Line Quick Disconnect Retrofit Qs Fryphax OEM Tech Discussion 15 July 22nd, 2008 01:53
Tranny Cooler in Radiator Fitting size? Weasel OEM Tech Discussion 0 August 2nd, 2007 15:34
Leaky Tranny Cooler Line/Fitting kyleboy7 OEM Tech Discussion 0 June 26th, 2006 22:30
Help! Pressure fitting on transmission cooler lines NotMatt OEM Tech Discussion 5 August 19th, 2004 12:58
Trans line fitting egon OEM Tech Discussion 3 February 21st, 2004 19:54
