Old September 11th, 2008, 10:16
Big_Al's Avatar
Big_Al Big_Al is offline
Disabling ABS
Swapped out the D35 for a Chry. 8.25 in my 97 XJ and was wondering what is the best method of permament disablement. I know many just pull the fuse for off roading but is this ok for long term? Thanks, Al
Old September 11th, 2008, 10:24
cherokee chuck cherokee chuck is offline
Re: Disabling ABS
That should be ok. I cut the sensors at the hubs, took out the ABS pump & used the plumbing and metering block off a non ABS, same year rig. The m/cyl is the same. Maybe it was overkill but it really cleaned up the left inner fender. On my sons 95 we just disabled the sensors & left the crap in there. If your pump is good you can probably sell it on Craigs list or E-Bay. Someone out there will need it, they go for up to $250 at wrecking yards.
Old September 11th, 2008, 10:25
xjtrailrider's Avatar
xjtrailrider xjtrailrider is offline
Re: Disabling ABS
I pulled the fuse, all 4 wheel sensors/wire harness's, and the ABS light.
I then notified my insurance company that the ABS was now removed from the Jeep but the brakes pass the VA safety inspection.
Old September 11th, 2008, 11:10
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Re: Disabling ABS
2000 XJ, I pulled the ABS relay in the PDC. I left all the plumbing and most of wiring in place. 2 + years, no problems.
Originally Posted by bimmerjeeper
Blanket caught in the rear liftgate latch. Now I can't open.
Old September 18th, 2008, 09:36
jason90xj jason90xj is offline
Re: Disabling ABS
need help i have a 90 xj tried to pull my abs swaped out master cycl. and booster i have brakes but my jeep won,t start? feel like an idiot but still need help.
Old September 24th, 2008, 04:31
Big_Al's Avatar
Re: Disabling ABS
Jason90XJ, You may want to start a new thread including all possible details. I though my thread here was long dead since it was so old. I don't have any advise for you but good lock, Al
Old September 24th, 2008, 09:43
Re: Disabling ABS
90 is a whole different ball game than the Mopar ABS. 2X on a new thread for your Bendix crap. Or do an advanced search if you haven't already.
Which fuses for disabling ABS? fast64 Modified Tech Discussion 10 December 30th, 2007 13:05
Disabling the 4.0? JeepXJ93 OEM Tech Discussion 26 December 25th, 2005 15:58
Disabling ABS on a 96 96XJCLASSIC Modified Tech Discussion 1 April 5th, 2005 13:56
Disabling ABS janorine Modified Tech Discussion 20 October 15th, 2003 09:16
Disabling ABS Aggie05 OEM Tech Discussion 2 August 1st, 2003 10:50
