Old September 3rd, 2008, 18:44
jdxj's Avatar
jdxj jdxj is offline
Brakes?
Will the brake rotors and callipers form a LP D30 out of a 01 work on a HP d30 from a 94? Thanks.
Old September 3rd, 2008, 18:45
cal's Avatar
cal cal is offline
NAXJA Warranty Voider
Re: Brakes?
If you switch the unit bearings and knuckles over too, yes.
In fact, you should switch the axle shafts too - they have bigger joints.
Old September 3rd, 2008, 18:47
jdxj's Avatar
Re: Brakes?
I thought the unit bearings were diffrant. Will the 01 bearings fit the 94 axle?
Old September 3rd, 2008, 18:48
cal's Avatar
cal cal is offline
Re: Brakes?
The knuckles and calipers have to be from the same year.
The unit bearings and rotors have to be from the same year.
It doesn't matter -what- year, just the same as the paired component.
Old September 3rd, 2008, 19:41
splitz's Avatar
splitz splitz is offline
Re: Brakes?
If you're going to change out knucles, why not go WJ?
(BTW I have no idea what i'm talking about, so I don't know if this mod works on all Dana 30s)
Old September 3rd, 2008, 19:44
cal's Avatar
cal cal is offline
Re: Brakes?
Very high cost
Very high complication
Figure $600 and the requirement of a good welder, if you use some used parts. If you go all new, its over a grand.
Old September 3rd, 2008, 19:49
jdxj's Avatar
Re: Brakes?
[quote=splitz]If you're going to change out knucles, why not go WJ?
That is my plan eventually. But I'm still saving up parts. Main reason to swap axels is my 01 has a LP( low pinion) and the 94 has a HP for better driveline angles.
On that thought though will the bearings from either work with the WJ Knuckles
Old September 3rd, 2008, 20:08
splitz's Avatar
Re: Brakes?
Originally Posted by cal
Very high cost
Not to tottally hi-jack and get too far off topic, but is it really that complicated? I've read the how to a few times now and I'm starting to gain confidence that I can do it (with some help).
I wouldn't do it unless I found a 99-04 Grand (I think that is the years) at the Pick and Pull. I would probably end up buying new rotors and definately new pads, and I haven't factored in the steering issues yet, but $600 for?:
WJ calipers*
WJ knuckles with caliper brakets and hardware
WJ rotors
1/4" hub spacers (buyJKS 930 here)
1/4" caliper spacers (easily made with a holesaw and drill press)
Brake fluid
Old September 3rd, 2008, 20:11
jdxj's Avatar
Re: Brakes?
Ya but if you do that then your steering won't work and new steering
Ends
Tie rod
Drag link
trackbar relocate bracket
Adds Up quick.
Old September 3rd, 2008, 20:17
splitz's Avatar
Re: Brakes?
Ends
Tie rod
Drag link
Adds Up quick.
Ok, you replied to my hi-jack so I don't feel so bad now.
I haven't factored in that part yet. I still have a lot of research to do on that. I picked up my ZJ tie rod for $12 at the PnP, so I'm hoping what ever type of steering I figure out, I can get the parts from there.
Like I said, I have no idea what I'm talking about. I'm learning as I go along, and talk out of my ass while doing it.
Old September 3rd, 2008, 20:23
jdxj's Avatar
Re: Brakes?
I'm getting my steering from Ballistic Fab. Here
http://www.ballisticfabrication.com/..._113-1337.html
But you can get what you need from JKS as well. And they have a lot of omfo on the swap on there site as well
http://www.jksmfg.com/
Go to the fab parts page and read and checkout all the parts. I think you can get it all for around $300. last I checked.
Don't worry about the Hi-Jack I'll forgive anyone ONCE :-)
Brakes SUA SPONTE Modified Tech Discussion 4 June 30th, 2007 12:19
brakes mgt Modified Tech Discussion 4 November 5th, 2006 06:00
Brakes, Brakes, give me a break. Fred OEM Tech Discussion 14 August 13th, 2006 17:44
Brakes questions (hit brakes and e brake light turns on) canadianwheeler OEM Tech Discussion 11 October 24th, 2005 21:00
Towing another XJ on a Dolly, Need Brakes to Light Up when i hit Brakes eric91xj OEM Tech Discussion 6 June 7th, 2003 16:41
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
