Old August 23rd, 2008, 22:07
LouisianaZJ's Avatar
LouisianaZJ LouisianaZJ is offline
NAXJA Member #1362
Turn Key, and no start, no lights, radio, windows, etc
Earlier today I rewired the CB to the radio fuse with a fuse tap
started and checked everything and worked fine. started later on and noticed the engine stopped (lights,etc) when the ac was turned on. had to restart
now when I turn the key nothing happpens....
underhood and interior fuses looked ok
92xj 4.0l
Old August 23rd, 2008, 22:17
NAXJA Member #1362
Re: Turn Key, and no start, no lights, radio, windows, etc
sound like the ignition switch?
Old August 23rd, 2008, 22:41
Stihl029's Avatar
Stihl029 Stihl029 is offline
hmm are you running anything in addition to the CB...like an amplifier? did you do a resistance check on your fuses? sometimes they may look ok; but have a minor break. you could always use a volt meter and start at the fuses on the block to see where you have voltage and where you don't.
Old August 24th, 2008, 00:11
NAXJA Member #1362
nope on the amp
Old August 24th, 2008, 10:45
philagony94xj's Avatar
philagony94xj philagony94xj is offline
sounds like the ignition switch to me. it can go out at any random time. if you dont know where its at just look under the drivers side dash attatched to the bottom of the steering column. just do a search of "ignition switch" and you should find all the info you would need to replace it.
oh and if it looks burnt then you know for sure thats the culprit.
Old August 24th, 2008, 11:34
NAXJA Member #1362
started up ok today
im guessing you right, im gonnapickup a new switch
is it on the bottom of the column or the top?? I have read it is best NOT to drop the column, is that coreect?
Old September 10th, 2008, 19:13
NAXJA Member #1362
Spent last weekend replacing the switch and cleaning up the wiring a bit. It started up several times w/o issue the day I installed the switch. figured it was fixed
tried it today for the first time since that fix, and back to the same problem...
I did notice one of the wires on the harness was burned up a bit (puple or red wire I think) I shoved it back into the harness and seemed to work OK the day of the install
Anyone have a writeup or diagram to convert this wiring to just a set of actual flip up switches? This is trail only, so not overly concerned of the security of it
Old September 14th, 2008, 17:46
NAXJA Member #1362
Ok, fixed the purple wire with a spade terminal and plugged the rest of the harness in. Now it works in ACC position, but notjing in the ON or start positions, does work halfway between on and start though. All fuses (underhood and under dash) tested OK
should I try a new switch? what are the relays for under the dash?
Old September 24th, 2008, 20:10
NAXJA Member #1362
tried new switch, same results
ACC position works. nothing works in the other positions, even the stuff that worked in ACC
with everything unplugged I am reading + 12 v on both red wires
and +.01 on the orange wire
still having trouble findign wiring diagram/listing for my 92. I have an 88FSM and 98 FSM, and they dont match up
this is what I have:
12 VOLT CONSTANT RED (+) IGNITION SWITCH HARNESS
STARTER YELLOW/GREEN (+) IGNITION SWITCH HARNESS
STARTER 2 N/A
IGNITION 1 BLUE (+) IGNITION SWITCH HARNESS
IGNITION 2 N/A IGNITION SWITCH HARNESS
IGNITION 3 N/A
ACCESSORY/HEATER BLOWER 1 PURPLE (+) IGNITION SWITCH HARNESS
ACCESSORY/HEATER BLOWER 2 N/A
Old September 24th, 2008, 21:02
makkman's Avatar
makkman makkman is offline
my 89 did this kind of thing shortly after i bought it... for mine, it turned out to be the junction point just aft of the battery under the junction cover.
From the battery, there should be 1 heavy wire going direct to the starter, and one to the junction.
yeah... electric gremlins are the best are they not?
best of luck to you...
Old October 14th, 2008, 21:54
NAXJA Member #1362
ok, iginition switch is ok. I have traced it back to the wiring somewhere between 2' infront of the bulkhead and right behind the fuse block. when I move these wires slightly the engine and radio loose power.
I guess its down to tearing apart the wiring and looking for cracked or melted wires
I HATE ELECTRICAL
Old October 19th, 2008, 18:19
NAXJA Member #1362
tore into some wiring this weekend. Took apart the harness at the firewall and cleaned it up. when I dod this the bottom set of wires was filled with MUD. after cleaning the mud out, I discovered a ~10 ga red wire had corroded away and fell out of the connector. I spliced in a 6 ga wire and spliced that to the corresponding 2x 10ga wires on the inside.
There was also a black w/ white trace wire that was corroded I spliced back, but that seemed to trace back to a pink wire with black trace? not sure why that was like that
Im gonna test drive it a few more times before I officially call this "fixed"
Turn signal lights lonecountryboy OEM Tech Discussion 6 July 9th, 2008 17:36
Dome lights won't turn off Giviner OEM Tech Discussion 4 July 6th, 2008 00:25
Radio And Fog Lights Cut Out 88XJSport OEM Tech Discussion 8 January 29th, 2008 12:39
Tail lights won't turn off! J33PsRock OEM Tech Discussion 7 January 2nd, 2005 00:21
lights won't turn off BPB OEM Tech Discussion 4 July 3rd, 2004 01:14
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
