Old June 27th, 2008, 07:14
Jeepm@n Jeepm@n is offline
231 to a 242 swap
Ok I searched and must be a complete idiot. I cannot find much info on the 231 to 242 transfercase swap on a 94 or 96 Xj with auto trans. Flame me if yah want I'd like some help from the search God's please. If anyone knows where there is a good write-up let me know.
Old June 27th, 2008, 08:14
BaronVonRoot BaronVonRoot is offline
Re: 231 to a 242 swap
not sure on the write ups, but i did a 242 to a 231 with a 4:1 teralow
problems i encounterd were spline counts on your output from tranny, to input on the new transfer, now I was working on a 89 XJ, I belive they went to a 23 spline out put on the later years but dont know enuff about the year switch, so splines will be your biggest issue, it will bolt right up, linkedge will bolt right up, but your plate in the jeep telling your shift points are off, the 242 case is a bit bigger I dont belive that creates any driveshaft issues, unless your looking for a slip yoke eliminator, there is not as much aftermarket products for the 242, dont know what your running as far as lift, but if anything over a 2 inch I belive you need a SYE... now when i was doing my resurch on this i didnt find much and what there was for the 242 was not great... thats why i went to the 231 insted, to go with my 5.5 lift, then I orderd a 4:1 teralow and it came with a 23 spline input and I had a 21 spline output on my tranny, now my fix was adding a Klune underdrive, to the mix now I have 2 transfers, lots of gears, I am told that its posible to change the output on the tranny to fix any issues... and now I wish I had gone to a atlas transfer insted, when I blow the 231 thats what I will be doing... dont know if this helps thats what I know... goodluck!!!
Old June 27th, 2008, 10:15
XJLI XJLI is offline
itll bolt right up. 242s in my experience are actually less prone to vibes. im running a tab over 3" and have no drop, no sye. the 242 is also arguable stronger than the 231 in a few ways, and teraflex does (from what ive heard) make a 4:1 for them, you just need to call them and ship them your case.
Old June 27th, 2008, 10:17
mattbred's Avatar
mattbred mattbred is offline
I did a 231 to 242 swap.
You'll need a new shifter gate for your lever (you need to remove your center console for this - don't worry, it's only like 4-6 screws).
The original linkage should bolt right up, and you will be OK on the splines. The only time you'll have an issue with splines is if you have a pre 91 jeep.
Old June 27th, 2008, 15:02
Ok so I need the gate for the shifter and the t-case is all? I have a line on a 97 242 t-case and my Jeep I'd put it in would be the 96. Drive shafts don't need changing? What about the Full time and Part time indicator lights?
Old June 30th, 2008, 01:35
mattbred's Avatar
For the lights, read this thread (I found the wire at the end of it in page 2):
http://www.naxja.org/forum/showthread.php?t=958721
Old June 30th, 2008, 08:07
ricot83's Avatar
ricot83 ricot83 is offline
NAXJA Member #1297
the shift gate can be modified to work with the 242, I did this swap twice with no problems and wired in my own led for the full time light. search and you will find a bunch of info
MY 44 SWAP TJWAXJ Modified Tech Discussion 8 February 18th, 2007 00:14
4.2 to ZJ V8 swap xjh3 Modified Tech Discussion 9 February 14th, 2007 18:03
Best 8.8 swap kit?? Where to buy? barillms Modified Tech Discussion 9 February 14th, 2007 08:43
4x4 swap XJay C. OEM Tech Discussion 1 May 26th, 2004 00:36
4 litre H.O swap vs. v8 swap... atowley Modified Tech Discussion 7 May 19th, 2004 13:40
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
