Old June 5th, 2008, 23:46
bhansen99xj's Avatar
bhansen99xj bhansen99xj is offline
Arrow Serp belt tensioner
Anyone ever snap the head off the serp belt tensioner? The one behind that power steering reservior. I snapped it off and am now in need of a replacement. Anyone have any suggestions?
Old June 6th, 2008, 05:56
Mudderoy's Avatar
Mudderoy Mudderoy is offline
Re: Serp belt tensioner
On my 98 I rounded off the bolt so bad that I had to remove everything and unscrew it from the piece sticking out the back.
Replaced the bolt, use the right size socket, and no problems.
Old June 6th, 2008, 06:34
xpanicax's Avatar
xpanicax xpanicax is offline
If there is a junkyard near you you could just pull one out of Jeep there. I have been meaning to hit up the junkyards near me just so I have a spare.
Old June 6th, 2008, 14:53
lawsoncl lawsoncl is offline
You're talking about the long bolt that does the actual tensioning? Seems kinda tough to snap that. Anyway, would simply welding a nut on there do the trick?
Old June 6th, 2008, 16:31
Problem solved guys, thanks. Just went the JY and grabbed another one. Now, to figure out this broken bolt holding my water pump on....
99 belt tensioner on 93 XJ czb83 Modified Tech Discussion 3 May 19th, 2008 13:30
TJ serp belt tensioner, maybe XJ also. BrokenXJ OEM Tech Discussion 2 January 6th, 2007 10:03
Belt Tensioner JeepCherokee OEM Tech Discussion 2 June 20th, 2006 22:31
belt tensioner bolt... dizzymac OEM Tech Discussion 5 August 5th, 2005 17:10
belt tensioner jeep_cj8 OEM Tech Discussion 3 July 11th, 2003 09:54
