Old June 3rd, 2008, 12:44
FordGuy's Avatar
FordGuy FordGuy is offline
Fan Overide switch Late Model
Yes I tried searching first! I have a 2000 XJ, I want to install a switch to override my Aux Fan. I want to do this because currently my Trans Cooler is mounted in front of the Radiator to take advantage of the Mechanical fan, Unfortunately this blocks a lot of air flow. If I move it to the other side it greatly improves the air flow and if I can override the Aux fan when Crawling it will cool the trans. My Idea is that if I tie into the ECU fan wire and install a Diode, and then intall a switch wired after the new diode, would this cause any issues I am not counting on.
Old June 3rd, 2008, 13:00
rstarch345 rstarch345 is offline
Re: Fan Overide switch Late Model
This ought to help you out http://www.soxja.org/forum/viewtopic.php?t=575
Old June 3rd, 2008, 13:02
srmitchell srmitchell is offline
http://www.projectxj.com/mods/stocker/fan.switch.htm
Im running this one, it has pics.
Its a really great mod.
Old June 3rd, 2008, 13:56
FordGuy's Avatar
My thoughts are why cant you just tie into the wire that goes from the factory ECU to the Factory fan relay, install a diode in front of the new wire so there is no feed back to the ECU and eliminate having to install a second relay etc..????
Old June 5th, 2008, 11:11
DaffyXJ's Avatar
DaffyXJ DaffyXJ is offline
NAXJA Member #929
I just dropped a relay and 10 gauge wire under the hood. spliced B+ into the fan hot lead off the harness, wired the relay to a switch and .... done. When the new switch is off the fan operates normally, when I want it on i flip the switch. The new switch is wired in parallel so no voltage issues.
my $.02
Old June 6th, 2008, 07:07
FordGuy's Avatar
my $.02
That was my first thought because of no ECU issues, then after thinking about it, is when I asked myself why not just use the factory relay and ECU feed with a diode in-line on the ECU feed. It eliminates all but one wire. Just trying to find someone to tell me if I am missing something because it is a ultra simple solution.
88xj to late model 4.0 bgoffroad OEM Tech Discussion 2 June 1st, 2007 10:28
Late model D30 knuckles P8ntu Wanted: Private Party Only 2 March 1st, 2007 20:12
Late model LIFTGATE - HOW TO crawldaddy OEM Tech Discussion 2 November 1st, 2006 10:59
late model AC problems whited OEM Tech Discussion 4 October 4th, 2006 10:28
Late Model Rear Defrost Switch Wiring??? Kirby N. OEM Tech Discussion 12 November 24th, 2005 09:58
