Old May 30th, 2008, 16:35
bigmcgiv bigmcgiv is offline
motor mount brackets
i keep breaking the mount bracket off on the right side. used grade8 and broke. looking for upgrade brackets. if seen m.o.r.e. brackets look great but steep in the pocket book. i heard of tj and goats. cant find those designs. please help me with more info. tks matt
Old May 30th, 2008, 18:17
magimerlin's Avatar
magimerlin magimerlin is offline
Re: motor mount brackets
Check these out. I just installed there motor mounts and the fit and quality was/is great.
http://www.browndogindustries.com/in...S&Category=136
Old May 30th, 2008, 19:17
any other ones out there thanks
Old May 31st, 2008, 04:33
does anyone know if you can use the stock mounts with the m.o.r.e brackets
Old May 31st, 2008, 10:24
sharq sharq is offline
ive had that problem before and ended up ruining a block trying to get the broken bolts out.
do you have a Tcase drop? hows your tranny mount?
maybe you can tap the block for bigger bolts.
Old May 31st, 2008, 11:33
its stock
Old May 31st, 2008, 11:45
Saudade's Avatar
Saudade Saudade is offline
I don't run them so I can say for certain, but the MORE mounts fit the stock bracket so I would guess the MORE brackets would fit the stock mounts.
I broke off 2 bolts on the driver side (3rd was loose). I was able to drill them out and replace them with hex heads (G8).
Old May 31st, 2008, 13:34
i did that and they broke in 4 weeks all new mounts also
Old May 31st, 2008, 13:45
you need to figure out why the bolts are failing. whats is causing the problem?
Old May 31st, 2008, 16:29
i change all 3 mounts and grade8 bolts on the right side bracket and now the mounts are all shot and broken bolts in the block again. unless im getting crappy mounts. i use it as my daily driver im not out there jumping off cliffs.
Old May 31st, 2008, 17:20
Gerr's Avatar
Gerr Gerr is offline
I seem to remember that theres a issue with stock bolts being to long and bottoming out before getting tight and breaking off maybe try a hair shorter bolt?
Old May 31st, 2008, 18:43
ZacSquatch's Avatar
ZacSquatch ZacSquatch is offline
Yeah, I use 1.25" long grade 8's and they work fine, I've brokin mine twice as welll. Drill a hole in the bolt, whats left, and easy-out it... Bout the only way.
Don't try the torch trick, it can ruin the block.
Old May 31st, 2008, 19:28
Saudade's Avatar
Hmmm... the good one I still had left was only 1 inch. I checked them in the holes before I put the bracket back on to make sure they didn't bottom out.
Old May 31st, 2008, 23:14
Jess Jess is offline
Not sure it would help or not, but I saw a bracket on a (IIRC) 2.5 MJ without AC in the salvage yard the other day that mounted to the frame rail on the passenger side near the front and to the timing cover (where the XJ alternator mount is). It seems this bracket would limit flex on the mounts and may prolong motor mount/bracket bolt life.
Old June 1st, 2008, 17:04
does anyone else make brackets besides m.o.r.e. or browndog
frt sway bar mount brackets magimerlin Wanted: Private Party Only 0 November 18th, 2007 09:14
motor mount not right? CDX74 OEM Tech Discussion 8 October 18th, 2007 10:26
Local Fab guy to Mount some brackets?? zjmikey SoCal Chapter 4 February 2nd, 2007 12:54
Motor mount smilesyota OEM Tech Discussion 5 October 14th, 2005 12:42
Exhaust Mount Brackets mgreen84 OEM Tech Discussion 2 August 24th, 2005 10:46
