Old May 18th, 2008, 23:33
czb83 czb83 is offline
99 belt tensioner on 93 XJ
I broke the belt tensioner on my 93 so I figured I could just fix it, or I could upgrade it. I chose the latter by getting complete 99 XJ intake, fuel rail, injectors, PS pump and bracket($60 at Junkyard).
I got everything on, but I've run into a problem with belt routing. I got the belt from the 99XJ, and went to follow belt routing of 99. It seems I need to remove the idler pully form AC bracket, though maybe I could just leave it there. Also, there is some metal round thing sticking out from what I think is the timing chain cover. If I tighten the belt, then it hits the metal thing. I couldn't find a post with someone having this issue before.
There are two solutions I can think of.
1. Shorter belt may help, but I'm not sure.
2. Grid off that metal piece, but I'm not even sure what its for, and what are the consequences of removing it.
Old May 19th, 2008, 04:40
j33pownr's Avatar
j33pownr j33pownr is offline
Re: 99 belt tensioner on 93 XJ
When I did the same swap if im remembering correctly, I had to reverse the pully tensioner so that it forced the pully down and to the right instead of up and to the left (I cant remember if my problem was what you were describing though). If you go this route to solve your issue you will needed to change the tensioner pully to a grooved pully instead of smooth pully because this will change the side of the belt the tensioner will ride on. This allowed me to use the normal belt routing on my 92 but it also lengthened the belt by a few inches. I hope that helped some.
Old May 19th, 2008, 06:02
Jes's Avatar
Jes Jes is offline
Remove the idler pulley at the AC and grind down the tube thing at the timing cover. I have a '93 also and that is what I did.
Old May 19th, 2008, 12:30
I gound off part off the timing chain cover, but it will still to close to belt. I then put back the AC idler pulley, which took up a little slack and I could tighten belt without it touching, but it is still pretty close. This is using the belt from a 99. I might try and find a smaller belt, so that I can take out AC idler pulley since it is just unnecessary resistance.
Belt Tensioner Question? please help dannemec OEM Tech Discussion 3 March 20th, 2007 20:21
TJ serp belt tensioner, maybe XJ also. BrokenXJ OEM Tech Discussion 2 January 6th, 2007 09:03
Belt Tensioner JeepCherokee OEM Tech Discussion 2 June 20th, 2006 21:31
belt tensioner bolt... dizzymac OEM Tech Discussion 5 August 5th, 2005 16:10
belt tensioner jeep_cj8 OEM Tech Discussion 3 July 11th, 2003 08:54
