Old May 14th, 2008, 17:02
iluv83vettes's Avatar
iluv83vettes iluv83vettes is offline
RRC Treasurer
Crown Vic Swap ?'s
I am in the middle of the Crown vic swap for disc brakes on my dana 44 and was wondering why no one re-uses the original retainer plates instead of getting the rubi ones. Also I was wondering how much play the axle should have sliding in and out with the retainer bolts tight. I put it back together with the original ones but I'm not about to drive it without knowing.
Old May 14th, 2008, 17:26
RCP Phx RCP Phx is offline
Re: Crown Vic Swap ?'s
You have to do something,the spacer IIRC is about .225".
Old May 14th, 2008, 17:30
RRC Treasurer
where does the spacer go?
Old May 14th, 2008, 17:34
http://www.madxj.com/MADXJ/technical...rDiscsOnXJ.htm
Old May 14th, 2008, 17:39
RRC Treasurer
ok what about how to make/where to get the spacer
Old May 14th, 2008, 17:43
Thats why everyone uses the Rubi plates,they are only 6$ each at the dealer!
http://www.stu-offroad.com/suspension/d44brake/bc-1.htm
Old May 14th, 2008, 17:56
RRC Treasurer
so you use both retainers then?
Old May 14th, 2008, 18:01
No,just the Rubi's.
Old May 14th, 2008, 18:05
RRC Treasurer
ok i figured it out. When I ordered the Rubi retainers from the dealership they gave me the wrong one. The one I got from them didnt have the extra lip thing and it was the exact same as the one on the cherokee except had the wrong bolt pattern. That last link you posted showed a better picture that I haven't seen before then I went and checked part numbers with what I had and what it says. Man that would have saved me a big headache.
What year crown vic el_roy1985 Modified Tech Discussion 10 April 20th, 2008 23:14
ZJ conversion or Crown Vic? jeepboy_90 Modified Tech Discussion 3 March 2nd, 2008 20:45
crown vic disc swap on d44? Tre Modified Tech Discussion 4 October 14th, 2006 14:41
Anyone actual done a Crown Vic disc brake swap? P1atinum Modified Tech Discussion 15 March 10th, 2005 21:48
Crown Victoria 8.8 Harvo Modified Tech Discussion 9 November 18th, 2004 17:15
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
