Old May 8th, 2008, 11:47
smcdonaldaz's Avatar
smcdonaldaz smcdonaldaz is offline
Best way to prep rusty expanded metal for paint
I have some expanded metal I'd like to lay in the bottom of my roof rack. It's lightly rusted and I need to know the least labor intensive way to prep it for paint. All ideas appreciated!
Old May 8th, 2008, 11:53
5-90's Avatar
5-90 5-90 is offline
Re: Best way to prep rusty expanded metal for paint
They make "flap wheels" that you can chuck into a drill motor - the "flaps" are small bits of sandpaper, fastened at one end. That should be about the easiest way to give the panel a good sanding.
Once you've sanded the loose rust off, wash it with HOT soapy water, and leave in the sun. Spray paint when dry.
Don't leave it out too long - just go until it's dry and able to take primer. Using hot water will help it dry that much faster, so you have it uncoated for a shorter time.
Old May 8th, 2008, 11:56
userbmx1315's Avatar
userbmx1315 userbmx1315 is offline
i cant find the link. but there was a thing on TRUCKS that you could use a bucket of water backing soda and a battery charger. no labor at all. could take a few days thats all
Old May 8th, 2008, 12:17
TunaSoda's Avatar
TunaSoda TunaSoda is offline
You would need a pretty big bucket to put your jeep in
Old May 8th, 2008, 12:23
yea. i wasnt thinking about the jeep. i was thinking about small parts. hahahaha. maybe the roof rack. but you will need you kids swimming pool,
Old May 8th, 2008, 14:29
I found this paint called "Rust Cap", supposedly you just give it a good once over to get any flakes off and paint it...
http://www.kilz.com/pages/default.aspx?NavID=42
Sounds easy to me! Company says it's @ walmart, lowe's, home depot, & ace hardware.
Old May 8th, 2008, 14:35
outlander's Avatar
outlander outlander is offline
Use a wire brush on it.Then spray permatex rust killer on it and let it dry for 24hrs then hit it with primer/paint.
In my experience if you dont completely remove the rust or chemical convert it it will rear its ugly head again.
Case in point:My floor board....I used that paint over rust paint that is supposed to stop rust.It didn't,thats why I'm in the process of stripping all the paint off and grinding/chemically treating it before the herculiner goes on.
Old May 8th, 2008, 14:51
TunaSoda's Avatar
POR 15?
You need to neutralize the rust before using the por
Old May 8th, 2008, 15:26
HaleYes's Avatar
HaleYes HaleYes is offline
Sandblast it.
Old May 8th, 2008, 16:23
89Daytona's Avatar
89Daytona 89Daytona is offline
http://www.metacafe.com/watch/456478/rust_removal_tip/
They have also used http://www.picklex20.com/
Old May 8th, 2008, 16:46
WheelinJR's Avatar
WheelinJR WheelinJR is offline
wire brush wheel in an angle grinder or drill.
OR
sandblast
Old May 8th, 2008, 18:07
poorboy_616's Avatar
poorboy_616 poorboy_616 is offline
I second the sandblasting.....
We had some expanded metal grates for the our teardown tables at Detriot Diesel, when they got too nasty, we threw them in the hot caustic tank for a half hour, when they come out they have surface rust due to the caustic soda, we then took them to the sandblaster to get the rust off, then we would mark (paint) where each engine should sit on the grate for easier teardown.....
Old May 8th, 2008, 18:58
5-90's Avatar
Sandblasting would be best, but not everyone has a sandblaster. Damn near everyone has a drill motor.
However, I didn't suggest using a wire wheel for a good reason - ever have one get caught in expanded metal? A good drill motor can send a half-sheet of that stuff flying, if you're not careful. The "flap wheel" shouldn't get caught in the stuff - I've used it before with good results.
Old May 10th, 2008, 16:06
Hammered's Avatar
Hammered Hammered is offline
I have two cup wire wheels i pul in the cordless drill. these can usually get the worst of the rust off stuff.
Old May 10th, 2008, 16:29
xjbubba xjbubba is offline
NAXJA Member # 1524
Muriatic acid is the trick
It's like phosphoric acid but WAY stronger. Don't use indoors!
And neutralize with water after the rust is gone, or the metal will disappear.
Expanded steel for gutter-mount rails smcdonaldaz Arizona For Sale/Wanted 0 April 15th, 2008 11:21
JV prep cal SoCal Chapter 19 November 19th, 2007 20:04
Gen-Right Crawler, expanded capacity tank IslanderXJ Modified Tech Discussion 11 January 31st, 2007 15:37
rusty bumper prep XJSpencer Paint and Bodywork forum 8 March 2nd, 2006 07:00
Metal prep before welding xxxj-va Modified Tech Discussion 15 February 27th, 2004 23:46
