Old April 12th, 2008, 17:03
crazyjim's Avatar
crazyjim crazyjim is offline
Where are you guys mounting your fire extinguishers?
I REALLY need to get one, but am up in the air about refillable vs. non-refillable, and how large, etc. I've been looking at the small 2lb kiddie non rechargeable but have also been thinking about a 5lb rechargeable...
So what are you running and where are you mounting them?
Old April 12th, 2008, 17:07
MT Mike's Avatar
MT Mike MT Mike is offline
Re: Where are you guys mounting your fire extinguishers?
5 lb rechargeable Kidd BC extinguisher mounted right at the left side seat base on my driver's seat, and a 5 lb Kidd ABC extinguisher mounted to the passenger rear wheel well (accessible from the back hatch). The one by the seat is for engine fires, and the one in the back is for anything else I may stumble upon.
Old April 12th, 2008, 17:09
crazyjim's Avatar
really the 5lb will fit there? Do you have any shots of it? I wouldn't imagine there being a whole lot of room there.
Having two is a good idea though.
Old April 12th, 2008, 17:11
MT Mike's Avatar
Give me a minute, I'll go take one right now.
Old April 12th, 2008, 17:13
crazyjim's Avatar
Sweet!
Old April 12th, 2008, 17:16
GrimmJeeper's Avatar
GrimmJeeper GrimmJeeper is offline
Dead man walking
mine is mounted where the spare tire mount is, never thought about engine fires.. maybe i should mount a second one up front somewhere!
Old April 12th, 2008, 17:23
silverslk's Avatar
silverslk silverslk is offline
engine fires dont happen to jeeps. Its not like they ran all the intake, fuel liines and exhaust all on the same side in a small confined area. haha
MT Mike's Avatar
The pictures doesn't show it, but the mount holds the extinguisher in two places, one at the top and one in the middle. I just used some self tapping screws to mount it to the seat base. It's been there for almost four years, and has never come lose when wheeling. I've used it once (car fire on the interstate) and had it refilled.
The one thing to remember no matter where you mount your extinguisher is to take it out once every six months and smack the bottom with a rubber mallet until you can hear the powder moving around. Otherwise it cakes into a ball and the extinguisher is inoperable.
Old April 12th, 2008, 17:24
IslanderOffRoad's Avatar
IslanderOffRoad IslanderOffRoad is offline
NAXJA Forum Addict
I've got a small one (2lb I think) mounted in the cubby on the rt side of the cargo area. came with its own holster that I screwed into the plastic.
John V.
01 XJ Sport 2 door 5spd/4WD- 4" lift, 35" BFG ATs, JCR bumpers, Rubi 44, Ford 8.8, 4.56's, ARBs
Old April 12th, 2008, 18:07
IllianaXJ's Avatar
IllianaXJ IllianaXJ is offline
Support Your Local Trails
I pulled the plastic trim off of the side of the seat and wedged it there. It fits perfectly and is tight enough I don't need a mount.
MWC Vice President
1995 XJ Sport Mallcrawler build
2000 GMC Yukon XL 2500 6.0/4L80e
Old April 12th, 2008, 18:14
T3hk1w1 T3hk1w1 is offline
I did the exact same thing as IllianaXJ
Old April 12th, 2008, 19:01
rocketman121 rocketman121 is offline
Old April 12th, 2008, 19:07
outlander's Avatar
outlander outlander is offline
Old April 13th, 2008, 14:16
EricsXJ's Avatar
EricsXJ EricsXJ is offline
NAXJA Member #616
Mine are right here.
www.ericsxj.com
Old April 13th, 2008, 14:30
waxer's Avatar
waxer waxer is offline
A lot of missle hazards in some of these pictures. Yikes!
HALON Clean-Agent Fire Extinguishers XpedientJ For Sale: Private Party Only. XJ ITEMS ONLY 12 February 14th, 2008 10:46
The importance of fire extinguishers scorpio_vette Non-Tech / Off Topic 6 May 21st, 2007 16:06
mounting a fire extinguisher Gnat5680 OEM Tech Discussion 10 July 26th, 2006 21:05
Winch Mounting (types of mounting) Lunatic728 Modified Tech Discussion 13 January 7th, 2004 09:03
Won't fire up!! XJZ OEM Tech Discussion 6 December 14th, 2003 21:12
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
