h_hezzah
- Cairo, EGYPT
My 99 XJ with 4 Liter Engine and AW4 had a front collision, and during repairs the engine and torque converter had been removed.
After the repairs It drives and shifts just normally, but without going into the 4th gear.
ATF Fluid has been replaced fully, so it's new. and filled with Dextron III to the correct level.
I tried the manual shifting test (ie. disconnected the TCU) and tried to shift manually, and it's still not shifting into 4th gear. (3 & D position makes no difference)
The TCU Diagnostic reads no error. So it's definitely a mechanical fault.
What should I look for next, and what could be causing this no shifting?
