Go Back   NAXJA Forums -::- North American XJ Association > Bargains and Deals > For Sale: Private Party Only. XJ ITEMS ONLY
For Sale: Private Party Only. XJ ITEMS ONLY Private Party Ads only. If they even smell commercial, they will be deleted.
Old March 20th, 2008, 16:38
XpedientJ's Avatar
XpedientJ XpedientJ is offline
NASCAR Detmar Cooling Fans - Ideal for Underhood Cooling...
I purchased this pair of 'Detmar' cooling fans from a South Carolina outfit. They were used in a NASCAR rig....for interior ventilation, as I understand it. I had intended to use them for underhood cooling, perhaps via thru-fender, or...??
I tested them, and they wind-up aggressively... Dimensions are 3" IN, 4" OUT, and one is 7" long and the other is 6" long. The longer one has a stepped-down flange on the output end, the other apparently had it, originally, but it was removed, and that one also has a bracket.
Slick-looking; great way to move some air.........
$38. shipped to the CONUS, for both.
Old March 20th, 2008, 18:11
Begster's Avatar
Begster Begster is offline
Re: NASCAR Detmar Cooling Fans - Ideal for Underhood Cooling...
You have a PM.
Electric Cooling Fans andyszafran Modified Tech Discussion 45 December 12th, 2007 00:22
underhood cooling nturboy12 Modified Tech Discussion 4 April 21st, 2007 14:08
Want to return to OEM cooling fans... meatplow5150 OEM Tech Discussion 9 July 5th, 2006 23:32
Aftermarket cooling fans Speed_racer Modified Tech Discussion 3 January 20th, 2004 12:09
aux. cooling fans wascobi OEM Tech Discussion 2 December 22nd, 2003 23:18
