Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Chapters > South East Chapter
South East Chapter Discussion of Chapter issues. Please keep Tech Topics on the Tech Forums.
Old February 12th, 2008, 08:17
userbmx1315's Avatar
userbmx1315 userbmx1315 is offline
welder advice. Chicago Electric
Chicago Electric 220V flux mig, 110A @ 15% duty. Less that 1 year old, used one spool of wire. $175
this welder still looks brand new, is it worth it? i want one that will weld 1/4" think steel, lookin at making my own bumper. i dont know if it has the bottle with it. it says mig so it should take gas shouldnt it? new at welders
Old February 12th, 2008, 08:27
ZacSquatch's Avatar
ZacSquatch ZacSquatch is offline
Re: welder advice. Chicago Electric
Thats what my buddy has been using for the past couple months on his ZJ project. Not a bad lil welder. Has trouble feeding at times though, we have to pull the wire with pliers every 5 welds or so..
He's been welding everything from unibody to 3/8's with it..
We just got a 160 tankt o run 75/25 this week.
$250 new I think.. may be worth it.
Has some pics of the beads it lays down and such here.
http://www.nc4x4.com/forums/showthread.php?t=34720
Old February 12th, 2008, 09:18
Achmed's Avatar
Achmed Achmed is offline
Just keep plenty of tips on hand and you wont be pulling wire every other weld.
Old February 12th, 2008, 10:34
ZacSquatch's Avatar
Neggatory Ghost rider... We changed tip quite a bit, the feed in the unit itself tended to slip and just spin without feeding wire. .030 and .035
Old February 12th, 2008, 10:39
Achmed's Avatar
My Chicao Electric doesnt act like that.
Old February 12th, 2008, 11:52
Archdukeferdinand's Avatar
Archdukeferdinand Archdukeferdinand is offline
I've heard of several others that do.
I scored a brand new lincoln 175 mig for $500 shipped, and if you're after something smaller the hobart handlers get a lot of rave reviews. I've seen the Handler 140 for as low as $375 shipped...
You won't be migging 1/4" with that CE machine, the manufacturer lists the max thickness of steel without mentioning that you have to use flux core to get the necessary penetration.
That said, it'll get you burning metal together right away. Personally, I'd suggest saving your pennies and getting a new unit from linc, miller or hobart. You'll end up with a more capable machine (good if you keep it) that keeps its resale value better (good if you don't keep it). Sometimes you just gotta get a new toy though.
Rate This Thread:
Joint Replacement Advice.... knowledgeable advice wanted! uncc civilengineer Modified Tech Discussion 2 February 21st, 2007 05:55
local chicago welder needed jjchgo Midwest Chapter 13 October 6th, 2006 05:38
getting a welder.. need advice 2000Cherokee Non-Tech / Off Topic 4 July 30th, 2006 09:38
Need welder advice. OT Non-Tech / Off Topic 19 January 18th, 2005 09:34
ready welder/century welder/portable welder? Redcbr007 Wanted: Private Party Only 1 June 6th, 2004 23:01
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
