Old February 11th, 2008, 16:34
AaronJXJ AaronJXJ is offline
bent my tail pipe
hey im brand new on the site as of today
but ive been reading the forums for a while today
i have a 2001 cherokee classic
my only mod right now is an OR-Fab front rock slider bumper
and i have a RE 3.5 lift waiting to be put on
anyway the point of this post is because i went out wheeling today with a buddie of mine
i was backing down off a hump i realized i couldent clear
while doing so i clipped my tail pipe, ripping it down and bending it
i was curiouse as to how harsh of a pinch would be required for me to replace the pipe
and if i have to replace it
if anyone knew a place to get a cheep stock tail pipe
i apreciate any feed back
Old February 11th, 2008, 16:43
RyanM's Avatar
RyanM RyanM is offline
Re: bent my tail pipe
Cut it off after the muffler and put a turn down on it
Welcome to ville
Old February 11th, 2008, 16:45
if i put a turn down on do i have to worry about any legal restrictions?
also do i have to worry about fumes?
Old February 11th, 2008, 16:52
WB9YZU WB9YZU is offline
NAXJA Forum Supporter
You have a number of options.
Remove the old pipe and try an straighten it. - Usually futile
Cut the pipe short and add a down turn. - Possible fumes, noise.
Replace the pipe and cut off the downturn. I cut it back at an angle and far enough in so it does not catch next time, usually about 2" shorter.
Not much cheap out there. You could try Rockauto.
Old February 11th, 2008, 16:57
alright, thanks alot
i really appreciate the assistance
Old February 11th, 2008, 18:30
jk333's Avatar
jk333 jk333 is offline
If you have an autozone near by ,the new tail pipe from the muffler back is about $25.
albush1's Avatar
albush1 albush1 is offline
Just get one from advance or autozone where they are inexpensive and you can get it the next day.
Old February 11th, 2008, 19:22
Gerr's Avatar
Gerr Gerr is offline
id cut it off at the muffler add a small 90* turn and exit it in the rear wheel well area. only time i get fumes in the cab area is if I have the back hatch open and idle which is the same problem if you had a 100% stock system
muffler tail pipe dilemma etaniyani SoCal Chapter 15 December 19th, 2007 02:09
trimming my tail pipe Blkxjkrawler Modified Tech Discussion 28 August 29th, 2006 07:14
90 XJ shooting fire out of tail pipe....please help me... MonsterXJ97 OEM Tech Discussion 10 November 30th, 2005 03:23
2.5 inch tail pipe aduke OEM Tech Discussion 2 April 16th, 2005 08:33
(tail) pipe dreams.. sidriptide Modified Tech Discussion 5 December 28th, 2003 13:08
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
