Old February 10th, 2008, 19:09
xj-boonie's Avatar
xj-boonie xj-boonie is offline
RE trackbar brace & Kevin's Trackbar conversion ?
Does anyone know if the RE Trackbar brace will work with Kevin's Off-road Trackbar conversion?
Thanks,
Mike
Old February 12th, 2008, 07:27
xj-boonie's Avatar
Re: RE trackbar brace & Kevin's Trackbar conversion ?
Anyone? or does anyone have a pic of how the brace attaches to the trackbar mount?
Old February 12th, 2008, 16:54
RCP Phx RCP Phx is offline
The RE brace will only fit the RE bracket(you might be able to modify it to work but it would take some work).
Old February 12th, 2008, 18:59
IllianaXJ's Avatar
IllianaXJ IllianaXJ is offline
Support Your Local Trails
I am going to attempt using the RE trackbar brace with the TNT bracket this weekend. It looks like it is going to work out with it mocked up. I had to replace one of the bolts with a carriage bolt so the superflex joint would clear, but otherwise it should work. I'll post pics after we get it done.
MWC Vice President
1995 XJ Sport Mallcrawler build
2000 GMC Yukon XL 2500 6.0/4L80e
Old February 12th, 2008, 22:01
Well the Kevin's bracket is a modified stock one(meaning no inside flat mounting surface to use.
Old February 13th, 2008, 23:52
lazyxj's Avatar
lazyxj lazyxj is offline
NAXJA Member #1310
The RE trac-bar bracket has a flat side for the brace to bolt to that the stock bracket doesn't have.
I added a brace to my Kevin bracket, modeled after the RE bracket.
I drilled out the bracket's tapered hole, the one that the stock trac-bar TRE used, to 5/8". This hole is used to bolt the brace to the trac-bar.
http://www.flickr.com/photos/lwade/s...7603825744373/
Both Cherokees are still Real XJs http://www.naxja.org/forum/showthrea...hlight=real+XJ
2001 Sport, 4 " lift, 33 X 10.50 KM2, DB, R.E.-UCA, JKS-LCA, ACOS, SYE, 4.56-8.25 TruTrac-D-30-E-Locker both with alloy shafts, Hidden M8000 winch, Vanco/Sport-Trac front and ZJ rear disc brakes, Frame stiffeners, Lots of armor, Towing baseplate. http://www.flickr.com/photos/lwade/c...7603770130683/
1997 Country, Mostly stock, 2" lift, Engine mods, Towing baseplate
HD trackbar bracket brace MG2000XJ Modified Tech Discussion 24 February 18th, 2008 06:48
#$@^&#(@*$ RE Trackbar brace Kejtar Modified Tech Discussion 7 April 8th, 2006 23:35
Rustys trackbar brace? tompatjr Modified Tech Discussion 6 April 1st, 2006 17:22
Staying at 3" lift, JKS trackbar or Kevin's offroad? deskjockey Modified Tech Discussion 9 September 23rd, 2004 13:24
RE Trackbar Brace DrMoab Modified Tech Discussion 14 April 9th, 2003 18:43
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
