Old February 6th, 2008, 06:52
mikegronholz's Avatar
mikegronholz mikegronholz is offline
Hard Brake Lines ...
... Where can i buy them ... none at Quadratec or Northridge. i am needing a hard brake line for the rear on a D44. Any ideas ?
Old February 6th, 2008, 07:35
codyj86 codyj86 is offline
Re: Hard Brake Lines ...
bend one yourself. i'm not sure you can even buy bent brake lines for that anymore. it's not difficult.
Old February 6th, 2008, 07:39
magimerlin's Avatar
magimerlin magimerlin is offline
X2 bend your own. Straight pieces in differant length with the ends already on them are availible at almost all auto parts stores. Its really easy to do as well.
Old February 6th, 2008, 07:42
That was option # 2 ... I have done it before ... I am of the convinience mind set right now ... if no one knows a location, I'll definitely bend some. Out of curiosity, how close would a TJ hard line be ? I am putting discs on, so the line doesn't need to be the exact length.
Old February 6th, 2008, 08:57
xj4fun's Avatar
xj4fun xj4fun is offline
I agree with the others. Either purchase a pre-maded line and bend it yourself, (or better yet) buy a double flaring tool, buy a pre-made line, bend it as needed, cut the excess on one end and create a new double flare.
It takes a bit of time to master, but it's a good skill to have as hard lines can get trashed when wheeling..
Hope this helps..
Brake hard lines: fitting sizes at master? bigolexj Modified Tech Discussion 1 February 26th, 2007 18:15
Stainless brake tubing(for hard lines)? wacho4 OEM Tech Discussion 5 February 23rd, 2007 15:05
brake hard lines thompson97 Modified Tech Discussion 6 October 20th, 2003 20:24
Replacing brake hard-lines CJS OEM Tech Discussion 5 August 17th, 2003 19:49
Hard brake lines bbaker80 OEM Tech Discussion 2 June 4th, 2003 21:23
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
