Go Back   NAXJA Forums -::- North American XJ Association > NAXJA's Technical Forums > Modified Tech Discussion
Register FAQ Users List Calendar Mark Forums Read
HOME Member FAQ Sponsor Info Rules Donate Bylaws Store Members Chat E-Mail
Old 01-15-2008
Frank Z's Avatar
Frank Z Frank Z is offline
Winter Project - 2008
Since I finally got the motor for our Stratus rebuilt and running and finished a few other odds and ends it's time to get busy on the XJ.
The first things I want to get done are redesigning the crossmember/long arms, add frame stiffeners, and swap out the transmission too.
First up, what it looked like before getting started....
Rock sliders are off...
Me getting the long arms unbolted...
Crossmember/xfercase skid is out...
Started cleaning up for welding on some frame stiffeners....
Old 01-16-2008
Frank Z's Avatar
Re: Winter Project - 2008
Passenger side is done, drivers side goes on tomorrow.
Old 01-18-2008
Frank Z's Avatar
Drivers side is done...
Old 01-18-2008
jragan jragan is offline
Looks nice, did you build the stiffeners?
Old 01-18-2008
Frank Z's Avatar
Yeah, used some 4"x4"x3/16" wall box tubing.
Old 01-19-2008
Frank Z's Avatar
Made a little progress today. Found out that the 98 transmission is set up a little bit different than my current 97 tranny. First up I had to remove the tailcone and swap the rear output speed sensor and rotor(changed from 1-pulse/rev to 4-pulse/rev.) You can see the 97 rotor on the bench beside the new tranny.
Seemed like a good time to replace the existing filter.
Yes I cleaned and reinstalled the magnets.
Daniel helped out today, couldn't have got the transmission in without his help (Thanks Son!!)
New transmission is now installed and the transfercase is back in palce as well. More work tomorrow as time allows.
Thanks for looking!
Old 01-23-2008
Caged94XJ's Avatar
Caged94XJ Caged94XJ is offline
Frank how are you going to wheel that thing with it torn apart... Looks good Frank... Let me know if you need any help...
Old 01-24-2008
Frank Z's Avatar
New crossmember is almost ready for primer and paint.
Started with this...
Now have this...
Still need to box-in the LCA mounts. Hopefully I can get it installed this weekend and fab up the new LA's.
Old 02-02-2008
Frank Z's Avatar
Got a little more accomplished since my last post...
Found a neat website to print out templates for coping tubes. Tried it out on the LA's.
First pic is the template after printing and cutting.
After tracing the desired pattern and grinding the tube the end result was pretty darn good.
New crossmember is on too...
Longarms are done and installed...and the tires no longer rub!!
Stay tuned.:beer:
Old 02-02-2008
tayman's Avatar
tayman tayman is offline
do you have any specs on your long arms? Any plans? I'm interested in building some very similar to what you have.
Old 02-02-2008
rcmf5525's Avatar
rcmf5525 rcmf5525 is offline
That is bad ass! I am thinking about fabbing a cross member as well. I can only hope it turns out that good. Keep the photos coming!
Old 02-02-2008
Stumpalump Stumpalump is offline
On a Time Out
Very impressive Frank! Those welds look a whole lot better than the ones I saw you do with a couple of batteries but those were quite impressive too! What didn't you like about your old long arm set up? And did you use you new home made bender to get that nice bend on your skid?
Old 02-02-2008
Frank Z's Avatar
Thanks all! No spec's or dimensions to share, building evrything on the fly so to speak. The previous LA's were almost exactly the same but the frame ends were directly under the frame. This allowed the tires to rub and limited my steering. The new design moves the frame ends inboard slightly so that the arms are perpendicular to each other. Since I welded the frame stiffeners on, the original crossmember was 3/8" to narrow so a new one was fabbed up.
The hoop that forms the transfercase skid was a spare that I had in the garage.
The bender should be finished tomorrow and I'll use it to complete the new sliders...stay tuned.
Old 02-02-2008
outlander's Avatar
outlander outlander is offline
Clean work there Frank.....
Got a link to the site that you printed the templates off of?And any info on that homemade bender also???
Were you worried about warping the unibody due to heat when you were welding these stiffeners up?
Old 02-02-2008
tayman's Avatar
alrighty then! how about this..... what kind of joints did you use?
U4WDA 2008 Winter Convention - St George, Utah U4WDA Intermountain Chapter 6 01-11-2008 14:48
Is it 2008 Yet? FELIX Fall Fling 2007 1 10-19-2007 06:45
winter (can we really call this winter?) projects Kejtar SoCal Chapter 69 06-02-2005 12:19
whats your winter project? sidriptide Non-Tech / Off Topic 44 10-27-2004 20:06
Winter RC crawler project done- PICS Incredible Hulk Non-Tech / Off Topic 9 03-21-2004 12:41
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
NAXJA and NAXJA logo's Copyright NAXJA. All content/images Copyright NAXJA 1999-2009
