Old January 13th, 2008, 12:14
resisfutal resisfutal is offline
On a Time Out
New here, first post. "brake lines/hard lines"
Hello, I have serched the forums for the answer to my problem and can't find it. I need to replace the hard lines for rear brakes on my '98 xj. Is there a place to get oem lines or do I have to make them myself?
Old January 13th, 2008, 12:19
98XJeep 98XJeep is offline
Re: New here, first post. "brake lines/hard lines"
it's easy to make them yourself, and prolly cheapr too
btw welcome to naxja
Old January 13th, 2008, 12:25
91Woody's Avatar
91Woody 91Woody is offline
If you have a double flaring tool it's easy- if not they will probably leak. While you're there you may as well get the extended stainless braided brake line that you will need in a couple months with the lift.
Old January 13th, 2008, 12:31
you can buy steel lines in lenghts to fit what you need, granted you might need to do some creative bending to take up some extra length.
Old January 13th, 2008, 13:03
Trail-Axe's Avatar
Trail-Axe Trail-Axe is offline
Welcome to .
Not sure if you tried this or not, but when you search, you can click on advanced search, and change the search parameters so the topic you are searching for comes up in the title. http://www.naxja.org/forum/search.php
This is what I found for ya, hope it helps.
http://www.naxja.org/forum/search.php?searchid=1900619
http://www.naxja.org/forum/showthread.php?t=75511&highlight=brake+hard+line
Brake Lines for 8" lift andrew2516 Modified Tech Discussion 11 January 23rd, 2007 14:48
Brake lines for 5-6" of lift? Double Down Modified Tech Discussion 16 November 4th, 2005 07:55
Brake lines & 8" of lift slvr98svt Modified Tech Discussion 0 August 22nd, 2005 18:53
5" lift and need new brake lines.. jjvande Modified Tech Discussion 3 January 1st, 2004 14:05
Extended Brake Lines for RRO 2" BB 96country Modified Tech Discussion 2 June 6th, 2003 06:20
