Old August 13th, 2006, 11:51
xjh3's Avatar
xjh3 xjh3 is offline
Rusty's Intake Tube
I am looking at the Rusty's Intake Package. Don't want to spend a lot, but also don't want to worry about stuff splashing in there if I want to hit a LITTLE mud. I searched and did'nt see anyone saying "DON'T BUY RUSTY'S INTAKE PACKAGE" like a lot of his other stuff, if anything people recomended it due to it's very economical price.
Any input would be appreciated.
Thanks
Old August 13th, 2006, 12:34
Littlewhitexj Littlewhitexj is offline
Re: Rusty's Intake Tube
Its just over priced, but its an alright product.
Skullver's Avatar
Skullver Skullver is offline
Still Flailing
Thanks
I run one, no probs as of yet, cheap for what you get, large K&N cone filter w/recharge kit.
Old August 13th, 2006, 12:36
w_howey's Avatar
w_howey w_howey is offline
I've got it. I covered the filter with foam prefilter for extra mud protection.
I do try and avoid the neverending swamp style mud though.
The prefilter I got is from some dirt track racing outfit. I don't know who though, I got it from a racer buddy.
AMSOIL Independent Dealer
beakie's Avatar
beakie beakie is offline
when I was younger and more naive I bought the K&N intake system, $400 I think total... waste of $300 IMO. I could have bought the filter, and some tubing to make my own for $100... or ordered the Rusty's package and be done with it.
I would say go for it, I have his exhuast package w/intake tube (gave the tube to a buddy since it was cheap add-on $)
Unless you swim your rig, or spends silly amount of time in water you shouldn't have much to worry about. If you spend that much time in water than the filter/engine is only one of your concerns for water damage.
Old August 13th, 2006, 12:45
xjh3's Avatar
Thanks for the replies!
That settels it-I'll order the Rusty's!
Old August 13th, 2006, 13:40
ckh550's Avatar
ckh550 ckh550 is offline
I just got some cheap sheetmetal from the True Value store, bent it up, drilled some holes and put it in place. Took about 20 minutes and a few bucks, and it's enough of a 'splash shield' to keep mud out of the filter and not block airflow at all.
Old August 13th, 2006, 13:48
DaffyXJ's Avatar
DaffyXJ DaffyXJ is offline
NAXJA Member #929
The only thing bad about Rusty's Intake tube kit OR any airbox replacement kit is that you are sucking in hot air from the engine compartment. I run Rusty's airtube kit, very simple, I like it with the exception that once the engine bay warms up, performance goes way down, though as I said this is the same with any cone in the engine bay set-up.
D
Old August 13th, 2006, 17:26
John90XJ John90XJ is offline
Ditto the warm air thing....especially without increasing the size of the filter.
In my trail rig I run a 9 inch long cone that is 6 inches in diameter. On the my street rig it's a K&N replacement panel filter in the stock airbox.
If the filter that comes with the Rusty's kit is still the K&N #0910 it's actually smaller in surface area than a stock filter. You might want to consider putting a K&N stock replacement in and running that instead. You get cooler air and a bigger filter than the conversion.
Old August 13th, 2006, 17:27
YMMV's Avatar
YMMV YMMV is offline
I love mine but do agree once it heats up, its twice as sluggish. Running a prefilter is a good idea i fgoing mudding or puddle jumping. here is a thread on how to make a heatshield. Very easy and even gives you dimensions. http://www.jeepforum.com/forum/showthread.php?t=245583
Old August 13th, 2006, 18:46
xjjeepthing's Avatar
xjjeepthing xjjeepthing is offline
I had one as well ,sold in favor of the stock airbox and a drop in K&N air filter.Too much hot air without a shield and it definetly doesnt like to get wet.
Old August 14th, 2006, 21:58
xjh3's Avatar
What about when I'm driving down the road and I've got lots of cold air coming in through the grill and stuff?
Old August 14th, 2006, 22:57
johnlv6's Avatar
johnlv6 johnlv6 is offline
The filter is exposed in the engine bay. The only way you're really going to see much of a performance gain is if you locate the filter in an area where it'll receive cooler ambient air (ex. snorkel). Get a drop in filter. You won't have the bling..but then again your wallet won't be $100+ lighter.
It's beyond me why you'd want an exposed air filter if you're going to do any kind of off-roading. The 5 hp or whatever you'll supposedly gain isn't going to outweigh the PITA that you'll have keeping the filter clean.
Old August 15th, 2006, 04:17
non-stick's Avatar
non-stick non-stick is offline
NAXJA Member #1288
I got the Rusty's air tube when I installed my aux battrey (needed the space the stock air box took up) and it does the job.
I had a K&N stock replacement element for about a month before the Rusty's kit and if I didn't need the space I would switch back to that setup in a heartbeat. Underhood temps means power loss (don't really care in 4L, but th etrip home can get annoying) and dusty trails mean I have to clean and oil the filter after every few trail rides, and there are not a lot of options on making it water "resistant".
I don't do a lot of water and I HATE mud, so the last issue isn't that major for me. If you want to do deep water crossings or are concerned with clogging the filter up, keep the stock box, snorkel it, and install the panel from K&N, you'll be happier in the long run.
HTH
Old August 21st, 2006, 22:26
xjh3's Avatar
Well today I got my airtube in the mail, and I put the big filter that I got at AutoZone on and took it out for a spin. The first strech of a 55 mph road I hit I floored it. There was a considerable increase (not an overwhelming) in pick up, especially in mid range or when already moving. But the best part is how cool it sounds. I love stomping on the pedal now and hearing that roar from under the hood. Depending on how things go as far as water resistance and heat, I may switch over to an AirAid kit, but for now I'm quite pleased.
Thanks to all who gave their input.
Lebaron hood vents and Tube intake jjmat3 For Sale: Private Party Only. XJ ITEMS ONLY 7 July 24th, 2006 13:17
Rusty's intake kit filters casm Modified Tech Discussion 16 July 15th, 2005 09:47
Rusty's air tube w/K&N BillR For Sale: Private Party Only. XJ ITEMS ONLY 3 August 27th, 2004 14:51
Rusty's intake tube Easyrydin2 Modified Tech Discussion 1 August 10th, 2004 00:52
Air intake tube to throttle body for '94 XJ Valkyr Wanted: Private Party Only 2 July 24th, 2004 06:45
