Old August 25th, 2003, 05:31
Amund2 Amund2 is offline
The driveshaft vibe
I'm really new to 4x4s, at least to owning one. I have brand new OME 2" (or something) springs on my 86 XJ, and didn't think I had any driveshaft vibrations. Now I'm unsure, however. Seems like there is a very fast vibration in the car when cruising around 100 km/h (about 60 mph), I don't know where it's coming from, but it feels like it's all around the car, in the floor, steering wheel, doors... not a strong vibration, not immediately noticeable but I can feel it, and don't like it... is it too little to damage/wear out anything, or should I look into it before it's too late?
Also, do you think this vibe (if it's coming from the shaft, I'm suspecting my gearbox mount as well, I think the steel touches sometimes, especially under forward torque) is due to driveshaft imbalance, or u-joint angles? I haven't checked the angles yet, but I got the shaft (and slip-yoke) from another car, which means the pinion yoke isn't balanced in relation to the driveshaft. I could try to turn the joint 180 degrees in the yoke, though... Or maybe I have bent my shaft, even just slightly? Does that happen easily, I noticed some screw-shaped scratches on the shaft, seems like I've touched something with it while driving...
All tips and opinions appreciated.
Old August 25th, 2003, 09:37
Kejtar's Avatar
Kejtar Kejtar is offline
PostMaster General
If you put on the lift just recently did you check to see if everything is tight? There might be something loose that is causing the problem.....
Also, try driving without the rear shaft and see if vibes are still there or not..
Kejtar
Old August 25th, 2003, 09:38
Kejtar's Avatar
PostMaster General
oh... with yours if you remove the shaft I think you will have to close of the t-case output.... Someone else will probably chime in with more info on that..
Front Driveshaft Rebiuld $$$?? cherokee89 OEM Tech Discussion 10 December 10th, 2003 15:04
Simple Rear Driveshaft Question OILBURNER Modified Tech Discussion 16 October 29th, 2003 14:00
driveshaft length thompson97 Modified Tech Discussion 5 May 27th, 2003 17:00
Front driveshaft compression travel available? SV1CEC Modified Tech Discussion 5 April 9th, 2003 23:13
Front driveshaft w\6-7" lift? Rudy Modified Tech Discussion 8 April 4th, 2003 19:54
