Old December 7th, 2007, 14:18
xj_mike's Avatar
xj_mike xj_mike is offline
Roof Rack Weight and Roof Load Capacity
Hi everyone. So I have this roof rack that I bought without actually knowing the weight of it. Well I found it is a little on the heavy side at 134#. Ouch!
Well, what I want to do is to remove the factory rack rails, put in larger Nutserts, put 3/16" flat stock where the factory rails would have gone and built mounts up to the rack, keeping it low profile to the roof. This is similar to the way Farmer Matt's roof racks were done. This way I am not relying on the gutters to hold the weight. I am planning my 31" tire, Hi-Lift, shovel, lights and a few misc. items as needed to be mount on this.
Will the roof hold the weight without causing problems? Anyone know what the weight of Farmer Matt's racks so I can compare to mine? Thanks!
XJ_Mike
1999 Cherokee Sport 4x4, Still stock...
2000 Cherokee Classic 4x4, Lots of stuff. SOLD but should have kept...
Old December 7th, 2007, 17:45
mecompco's Avatar
mecompco mecompco is offline
Re: Roof Rack Weight and Roof Load Capacity
I dunno, but my Surco mounted to the roof rails held my buddy and my 33" spare w/no problems--that's around 250 lbs. or so.
Old December 20th, 2007, 09:28
FarmerMatt FarmerMatt is offline
My racks had a shipping weight of 60# & could easily handle a 35" spare along with packing it down for a long camping trip. 3/16" for the rails might be a little overkill. Consider dropping down to 1/8" strap or lighter if you build it right...
Old December 29th, 2007, 16:26
xj_mike's Avatar
Thanks for the info guys!
XJ_Mike
Roof rack max weight? POSJ OEM Tech Discussion 3 May 6th, 2007 15:16
roof rack max weight? siminsez01 OEM Tech Discussion 13 September 20th, 2005 14:18
Roof rack weight, how heavy is it? corbinafly Modified Tech Discussion 3 July 16th, 2005 07:40
Home built roof rack weight? GroversXJ Modified Tech Discussion 26 April 3rd, 2005 15:51
Yakima Load Warrior Roof Rack 2XJ Wanted: Private Party Only 0 May 15th, 2004 17:36
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
