Old November 15th, 2007, 09:20
Macedo Macedo is offline
Auto trans rebuild
Hi,
Iīm new here in this forum and I have a cherokee xj 1998 and iīm rebuilding the auto transmission.
My automatic transmission model is AISIN 30-43LE. I think that this model is
the same of A340E. Am I correct?
Wich brand is a good one to buy a rebuild kit?
Where i could find online?
Thank You.
Old November 15th, 2007, 09:25
1985xjlaredo's Avatar
1985xjlaredo 1985xjlaredo is offline
Re: Auto trans rebuild
What? I thought that all 4.0L XJ's came with AW4's in them.
Old November 15th, 2007, 09:28
Nine Mile Nine Mile is offline
If you have any junkyards in Brazil, you'd be better off swapping in a used unit...
Old November 15th, 2007, 09:31
JoshRountree JoshRountree is offline
The AW4 may be identified as a model #30-43LE for 2wd versions and as a model #40-30LE for 4wd versions.
From http://www.novak-adapt.com/knowledge/aw4.htm
Old November 15th, 2007, 09:37
Originally Posted by JoshRountree
Thank you Josh.
My cherokee is a 4wd version, itīs possible to came with the AW4 30-43LE?
This is the same thing of A340E?
Old November 15th, 2007, 09:43
From that website it says your transmission is a 2wd. Did it come with 4wd, or was added later? And like Nine Mile said, it's probably cheaper to just buy a low mileage one from the junk yard. They're pretty tough transmissions but some haven't done well after a rebuild. As long as it has fluid in them the junkyard ones usually work well.
Old November 15th, 2007, 10:13
jeepcomj's Avatar
jeepcomj jeepcomj is offline
it's an aisin warner 4 or AW4 transmission. absolutely no doubt about that, so when you buy a rebuild kit that is what you want.
rebuilding an aw4 is almost considered dumb (no offense)..you can buy a good one to replace the entire transmission.
you cannot turn an aw4 2wd transmission into a 4wd without swapping output shafts...which would mean they had it completely apart already once. it's smarter and easier to buy a 4wd trans and drop it in if you're going from 2wd to 4wd.
as stated, if you have any junkyards or ability to get a good AW4 around where you live, do that before you rebuild it.
Old November 15th, 2007, 10:25
My cherokee came with 4wd. In Brazil is not common to find this kind of transmission in junkyard. Itīs cheaper to rebuild.
My transmission only have the problem with the gasket kit and seals. My friction plates and steel plates are not so bad. But considering that a master kit is around US$200,00 and iīll pay US$700,00 just for the labor (mechanic), i think itīll better to change the master kit and stay with a good transmission.
Why is not a good idea to rebuild a 4wd? Because the costs in USA between a rebuild process and a used one or the quality after the rebuild?
Old November 15th, 2007, 10:39
Rob Mayercik's Avatar
Rob Mayercik Rob Mayercik is offline
NAXJA Member #920
Cost of junkyard replacement vs. rebuild is likely the major factor for those of us in the U.S.
There's also the fact that these transmissions don't seem to fail that often, so there's fewer dead ones to need rebuilding.
Rob
1992 Cherokee Laredo: "A wonderful balance of grace and rust"
1984 Dodge Omni
2002 Volkswagen Jetta GLS TDI
Old November 15th, 2007, 10:48
aparke4's Avatar
aparke4 aparke4 is offline
yeah i really only see these trans. on wrecked vehicles at smaller yards - bigger like PAP will have them on the shelf ready to go most of the time - smaller yards will pull them for ya but they are not worth as much as other engines and trans. so they spend more time on engines, other trans, etc that are worth more - man for 700 you could just about swap a 318 or 350 and turbo 300-400!
Old November 15th, 2007, 11:12
jeepcomj's Avatar
yep. cheaper to swap an auto in than rebuild here.
I have one with 280,000 miles on it and it's going in a low miles cherokee right now cause it has a good 200,000 miles left in it most likely, and the xj it's going in needs to be 4wd not 2wd. if it blows up, the cost now is $0 (since I already have it) so replacing it with another used one wouldn't kill me at a price of ~$200
AX15 trans rebuild/overhaul alex.brence Wanted: Private Party Only 0 September 8th, 2004 00:22
need 2x auto trans for 2.5 rockwerks Wanted: Private Party Only 5 July 17th, 2004 18:46
does downshifting with an auto trans to slow or brake hurt the trans lapaul OEM Tech Discussion 12 February 21st, 2004 09:26
88 XJ auto trans GTsenre Modified Tech Discussion 7 September 21st, 2003 11:00
AW4 Auto Trans chris87 For Sale: Private Party Only. XJ ITEMS ONLY 0 September 14th, 2003 19:13
