Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Other Technical Forums > Jeep Street and Performance
Jeep Street and Performance Do you like to go fast in your Jeep?
Old November 3rd, 2007, 01:40
kremlin's Avatar
kremlin kremlin is offline
Exclamation 2000 TB / Intake to 1988 Renix XJ
I've a 2000 TB / Intake to 1988 Renix XJ. What mods can be done to get this to work properly ?
Old November 3rd, 2007, 01:56
5-90's Avatar
5-90 5-90 is offline
Re: 2000 TB / Intake to 1988 Renix XJ
I'll get to you before you get jumped on - you really should search, with keywords like "HO Throttle Body." I know this has been covered - in depth - with pictures - here. I just don't have a link handy...
Old November 3rd, 2007, 02:25
BIGSLVRXJ's Avatar
BIGSLVRXJ BIGSLVRXJ is offline
For it to work properly you need to get an HO head and bolt it to your Renix block. You will also need to modify your TPS. Like 5-90 said, it has been covered extensively here, if you use the search function looking for my name associated with the threads you will find a ton of info.
1990 XJ Pioneer-5.3 swap in progress-Original "BIGSLVRXJ"
1997 XJ Country-4.0, AW4, NP231, D30, C8.25, 4.5" RE Lift, 32" KM2s "BUMBLEBEE"
2001 XJ Sport-4.0, AW4, NP231, D30, C8.25 "Stock"
-Collin
Old November 3rd, 2007, 03:54
Bouncy's Avatar
Bouncy Bouncy is offline
I don't think he can use the 2000 TB but I could be wrong. I can't remember if it was 2000 or 2001 that the TB was changed. Different sensors.
Its early...I may be thinking of the 2003 rubicon. The TB was a different setup, different sensors, different cabling.
End result...a TB from 92-99 will work on an 88 easily. Just adapt the TPS spacer. All other sensors bolt up.
Old November 3rd, 2007, 07:14
summitlt's Avatar
summitlt summitlt is offline
Except the Renix intake has a 3 bolt throttlebody and different everything. Thats all.
Old November 3rd, 2007, 08:32
Slo-Sho's Avatar
Slo-Sho Slo-Sho is offline
To make this swap work you will also need from a H.O.;
1.Power steering bracket w/ tensioner
2.96+ XJ Power steering pump
3.H.O. Throttle cable
4.H.O. Fuel rail
5.Air box to TB hose
You will also need to extend the fuel lines and fabricate the Renix-H.O. TPS adapter.
To get the most out of this swap you will also want the H.O. cylinder head. Whether or not your renix is got piston slap (mine did, bad) you may as well just get a whole motor from the U pull it yard from a 96+ and drop in.
Old November 3rd, 2007, 13:16
kremlin's Avatar
Thumbs up Re: 2000 TB / Intake to 1988 Renix XJ
5-90 : ! Thanks for the Intro. !
90PioSport99 : I'm on page 5 of your 34 pages of threads - Primo Site.
I'll find a 7120 '93 head somewhere for this 1982 Eagle 2dr.
Sedan project.
Bouncy : I'll research the Throttle Bodies & get the best 'Yardage' -
how about something from a FORD or Nippon - ?
summitlt : It's easier to identify when nothing else matches !
Slo-Sho : My 1989 XJ 5spd.
175K Renix has - no piston slap yet !
This Eagle 2dr. Sedan has a 258 with a rebuilt trans and a
50K 258 parts car.
I have an '88 Cherokee ECM / TCM / Intake etc. and a
harness 'cut cleanly' at the firewall in the parts box -
along with an AW4 bell housing in case I don't like the
wider Torqueflite gearing.
Also have an '84 4spd stick
Eagle parts wagon.
I'd like a serpentine belt system -
A Renix exhaust header is needed for the exit path in Eagles.
Has anyone laid out how to sort out a Harness for Renix
EFi conversion ?
I could yank the powertrain & swap in a '96 Up, but the
258 is healthy + I have a 50k 258 + the orig. Torqueflite is
'Fresh' + I like and want a ReniX EFi system - so it seems
I'm in for the full Tour!
......... more weekend reading Ahead...... thanks gents !
Rate This Thread:
1988 4.0L Renix Rebuild avnsteve OEM Tech Discussion 41 January 2nd, 2008 20:04
Renix 1988 hi idle at start up markaboo929 OEM Tech Discussion 5 June 21st, 2007 10:47
1988 Renix Coil Question 1985xjlaredo OEM Tech Discussion 12 May 9th, 2007 21:02
1988 Renix TPS readings gator_grabber OEM Tech Discussion 16 February 24th, 2004 14:57
FA: EBAY 1988 JEep Cherokee Intake manifold, Complete Tim88XJ For Sale: Private Party Only. XJ ITEMS ONLY 2 November 5th, 2003 13:05
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
