Old October 27th, 2007, 16:36
Fred's Avatar
Fred Fred is offline
NAXJA Member #15
2000 XJ 4.0 Intermittent No Start
All right, actually it's 99 in a WJ, but the engine is the same as the 2000 XJ.
I've been having an intermittent no start problem. Seems to happen after the Jeep is warmed up when my wife is out running errands. It still turns over, just won't fire. It has never happened first thing in the morning going to work, or coming home in the evening. It seems as though if it is left to sit for at least 1/2 hour it will start with no problem.
It runs well. I've recently replaced the tranny speed sensor, and the neutral safety switch, which I thought might have been the problem. My OBD II reader does not show any problem when it is not starting.
I'm afraid I may actually have to take it to the dealer, and I'm also afraid they'll pronounce it "fixed." and it won't be. I'll just be out time and money.
Fred
[Q. Why do the British drink warm beer?
A. Lucas wires their refrigerators too.
Old October 27th, 2007, 17:07
JNickel101's Avatar
JNickel101 JNickel101 is offline
Re: 2000 XJ 4.0 Intermittent No Start
is it throwing any codes????
EDIT: missed that part of your post....
it never throws the CEL? you dont even get a "no bus" on the odometer?
Old October 27th, 2007, 17:27
JNickel101's Avatar
I'll probably get flamed for this, but my first guess would be the CPS (crank position sensor) - but usually if that is bad, it will throw a code.
Old October 27th, 2007, 17:52
Fred's Avatar
NAXJA Member #15
I'm inclined to that answer myself, but I don't understand why it doesn't throw a code.
Fred
Old October 28th, 2007, 08:15
ahm's Avatar
ahm ahm is offline
check the wiring along firewall(not the big one), it has wires for CPS & Cam sensor, and goes to computer. Check for contiuity from one end to other. I replaced cam & crank sensor & truck still runs sometimes and wont start others. Jeep checked sensors & they were good & they werent sure what to do next. goodluck
Old October 28th, 2007, 22:42
scorpio_vette's Avatar
scorpio_vette scorpio_vette is offline
there's a 50/50 chance of the cps throwing a code. to many people depend on the cps throwing a code and therefore overlook the cps sensor. often times it still turns out to be that.
AC on 2000 XJ intermittent snowjeep OEM Tech Discussion 1 August 17th, 2007 07:25
2000 classic Cruise Control intermittent at best pwoens OEM Tech Discussion 15 August 10th, 2007 07:18
2000 XJ Sport A/C Intermittent Failure? rbarton OEM Tech Discussion 7 July 7th, 2007 15:03
flooding/no start intermittent thall OEM Tech Discussion 11 January 13th, 2007 13:13
VERY strange & intermittent no start TK99XJ OEM Tech Discussion 8 October 3rd, 2006 12:53
