Old October 25th, 2007, 21:50
4x4fish's Avatar
4x4fish 4x4fish is offline
Battery Terminal replacement
Anyone know how easy it is to replace the battery terminals? Mine are getting pretty coroded and dont sit to tight on the terminals posts anymore.
Old October 25th, 2007, 21:56
KarlVP's Avatar
KarlVP KarlVP is offline
Re: Battery Terminal replacement
Battery terminals? Or battery cables?
The cables can be had for about five bucks a piece at your local vatozone.
Old October 25th, 2007, 22:49
4x4fish's Avatar
The metal piece at the end of the cable that goes over the terminals on the battery itself.
Old October 25th, 2007, 22:53
KarlVP's Avatar
Any parts store will have the whole cable with the ends on it for less than ten bucks.
Old October 25th, 2007, 23:15
Stihl029's Avatar
Stihl029 Stihl029 is offline
Hey just so its out there you can replace the terminal posts on the battery as well...depending on what type of battery it is. I have had to do it on some of the Bigger UPS systems that we have, when someone screws up.
Old October 25th, 2007, 23:24
5-90's Avatar
5-90 5-90 is offline
On heavy truck batteries? Sure.
On large (BCI 27) batteries? Sometimes.
On passenger vehicle batteries? Not that I've seen (although there are times I'd like to have been able to...)
Old October 27th, 2007, 13:23
4x4fish's Avatar
This is what I'm looking for, where do the cables go from the battery and is it easy to disconnect and replace? Thanks 4x4fish
Old October 27th, 2007, 14:05
Yucca-Man's Avatar
Yucca-Man Yucca-Man is offline
NAXJA Member # 683
The cables are very easy to replace - remove the nuts on either end that attach them. Remove the negative ( - ) cable first, and reconnect it last.
Jim www.yuccaman.com
Positve battery cable replacement spaulman OEM Tech Discussion 2 March 18th, 2007 20:12
Looking for BRASS terminal cap/rotor for 4.0 oldmustangjunkie OEM Tech Discussion 13 February 26th, 2005 10:25
Feeler - Replacement Battery Cables... 5-90 Modified Tech Discussion 13 January 27th, 2005 12:42
Keyless entry battery replacement Headache OEM Tech Discussion 2 November 13th, 2004 14:42
Battery Pan - Replacement woogie Modified Tech Discussion 3 September 11th, 2003 16:43
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
