g13092
- Chicago 'burbs
Oh well, here we are again. '00 XJ sport shakes like a leaf when braking. I had some vibes in May that varied with brake application, but also persisted when going 50mph. Wheel balance solved the 50mph problem (one wheel was definitely way out), but there were still vibes when braking. Using autozone parts (calipers were replaced under lifetime warranty) I put on new calipers, pads, rotors, flushed fluid, good bleeding. All was well for about 4k miles.
The last brake job lasted ~30k miles, this one ~4k? Any thoughts?
I can think of 2 discussion points. 1) The caliper bracket 'slides' on which the pads rest have some grooving, maybe the pad is hanging up, or 2) A bad hub is causing strange brake wear. I had a squeak a few winters back, only when just moving from a cold soak. Was sure I'd have to change a hub, but the squeak went away and hasn't come back.
I'm getting tired of doing brakes on this thing!
